Температурный перепад по сечению балочного элемента
Юмористические расчеты, комедийные диссертаций, цирковые статьи
не всякий элемент точно.
расчеты МКЭ и CFD. ктн Регистрация: 11.05.2005
Подмосковье
я же предложил читать хелп.................BEAM188
ну что ж мне за вас это делать= ВСЕ ЯСНО НАПИСАНО At both ends of the element, temperatures can be input at these locations: At the element x-axis (T(0,0)) At one unit from the x-axis in the element y-direction (T(1,0)) At one unit from the x-axis in the element z-direction (T(0,1)) Element locations (T(y,z)) are given according to the convention used in Figure*188.1:*BEAM188 Geometry. For beam elements, element body load commands (BFE) accept an element number and a list of values, 1 through 6 for temperatures TI(0,0), TI(1,0), TI(0,1), TJ(0,0), TJ(1,0), and TJ(0,1). This input can be used to specify temperature gradients that vary linearly both over the cross section and along the length of the element. The following defaults apply to element temperature input: If all temperatures after the first are unspecified, they default to the first. This pattern applies a uniform temperature over the entire element. (The first coordinate temperature, if unspecified, defaults to TUNIF.) If all three temperatures at node I are input, and all temperatures at node J are unspecified, the node J temperatures default to the corresponding node I temperatures. This pattern applies a temperature gradient that varies linearly over the cross section but remains constant along the length of the element. For any other input pattern, unspecified temperatures default to TUNIF. Alternatively, temperatures at nodes I and J can be defined using nodal body loads (BF,NODE,TEMP,VAL1). When using a nodal body load to define a temperature, a uniform temperature is applied over the cross section at the specified node. |
Расчёт подпорной стенки на климатические воздействия (перепад температуры по сечению) | Mozgunov | Конструкции зданий и сооружений | 33 | 08.02.2016 09:45 |
Расчет пространственных стержневых систем и наличие шарниров в расчетных схемах | Jenec | Лира / Лира-САПР | 17 | 27.09.2013 22:23 |
Температурный перепад трубопроводов в узле управления теплоснабжения. Как исправить ситуацию? | sapr71rus | Инженерные сети | 8 | 17.04.2012 12:05 |
