Architectural Desktop 2004 (english) + SP2 = ?
hello
This is a right method: 1. uninstall all ADT 2. check 33th physical sector on harddisk, it must be clean You should not use Again keygen, just use network licence licpath.lic: 3. istall ADT 2004a. 4. register with licpath.lic 5. save adlmdll.dll 6. istall ADT 2004 SP2 7. import "acad_archi.reg" from "\crack" dir into your registry 8. replace adlmdll.dll with saved one. 10. enjoy |
No my friend, I used Google to search for ADT 2004 SP2 crack, then world.altavista.com to translate (badly, but worked somehow) the results. Plus, the phpBB layout is universal and easy to navigate, so I tried to post in the right section of the forum (therefore I used the same section as the previous question I mentioned)
![]() "Interestingly, he does not like speak on Russian, but it fell here. It means can, but it does not acknowledge." Интересно, вроде не говорит по русски, а попал сюда. Значит может, но не признается. It doesn't need some kind special intelligence to do it ![]() |
