Получил ник, расшарил папку, подключился нормально, установил пароль, перегрузил клиент.
При попытке поиска получаю следующее: [19:25:07] <DWGHub> Active Search: Your ip is not 192.168.1.162 it is хх.хх.хх.хх bye bye. [19:25:07] * Ошибка: Соединение закрыто... [19:25:23] * Подключение к 89.108.122.65 [19:25:23] * Подключен к 89.108.122.65 [19:25:23] <DWGHub> This hub is running version 0.9.8e-r2 (Monday Jul 20 2009) of VerliHub (RunTime: 27weeks 5days / Current user count: 0) [19:25:23] <DWGHub> This hub is enhanced by plugman for Verlihub. [19:25:23] * Отправлен сохранённый пароль... [19:25:23] <MOTD> This file contains the text that will be displayed to users upon entering the hub. Change it to suit your needs or use the file trigger definition to store your motd. Welcome to Verlihub +rules -- Displays a listing of the hub rules. +faq -- Displays a list of helpful links if you are having trouble. +motd -- Redisplays this message. +help -- Displays a list of all commands available to you. Dependent upon user type. The verlihub project's homepage is located at http://www.verlihub-project.org The verlihub forums are located at http://forums.verlihub-project.org [19:25:23] * Тема хаба: No Description [19:25:23] <DWGHub> [::] Your info: [::] Nick: GordonF [::] Class: Registred (1) [::] IP: хх.хх.хх.хх [::] Reg Information: [::] Nick: GordonF [::] Class: 1 [::] Password set:Yes [::] Last login: Sun Aug 4 17:09:10 2013 [::] Last IP: 90.151.92.0 [::] Last error: Thu Jan 1 03:00:00 1970 [::] Error IP: [::] Login count: 4 [::] Login errors: 0 [::] Protected: No [::] Hidden kicks: No [::] Hidden keys: No [::] Hidden share: No [::] Registered since: Sun Aug 4 10:44:01 2013 [::] Registered by: Borg [::] Alternate IP: |
За роутером? Необходим переброс портов.
Admin, зарегистрируй ник i3238 на хабе, пожалуйста! Что-то у меня проблемы с заходом, разбираюсь.
Сначала заходил нормально, некоторое время назад действительно стал ругаться на недопустимые символы в нике
[23:16:30] **** Соединение с 89.108.122.65 ...
[23:16:30] **** Соединён [23:16:30] <DWGHub> This hub is running version 0.9.8e-r2 (Monday Jul 20 2009) of VerliHub (RunTime: 1hours 40min / Current user count: 1) [23:16:30] <DWGHub> This hub is enhanced by plugman for Verlihub. [23:16:30] <DWGHub> <<User limit exceeded, hub is full.>> Online users =1 [23:16:30] **** Соединение закрыто Такое впечатление, что аккаунт вообще не принимает |
Шото тоже не робит...
[19:03:46] <DWGHub> <<User limit exceeded, hub is full.>> Online users =0 [19:03:46] *** Connection closed Заработало. А там на хабе всегда так пусто, или вчера ЧП было? Последний раз редактировалось Pavel_V, 04.10.2013 в 09:37. |
Да, сохранилась
