Architectural Desktop 2004 (english) + SP2 = ?
Вернуться   Форум DWG.RU > Программное обеспечение > Прочее. Программное обеспечение > Architectural Desktop 2004 (english) + SP2 = ?
Непрочитано 01.04.2004, 04:52 #1
ADT2kx
Hello
I'm sorry to post this in english, but unfortunately I don't speak russian. A friend has ADT 2004a (PANTHEON rls, international english version with network license) and tried to install SP2 (locked version, unlocked doesn't work with this release) on top. As expected, he received error, so he did a clean installation (after checking the registry for remaining references to old files) and used the AGAiN keygen. He used the old serial in the authorisation dialogue. ADT works now, but Viz doesn't.
I found at http://autokad.ru/forum/viewtopic.php?t=193 a 2 months old similar subject, but the online translator isn't good at all and can't understand everything, If I understood right, he has to keep the adlmdll.dll from the original clean installation, install the service packs, then authorise with the keygen and place adlmdll.dll on top? Is there any other crack that works with SP2?
Any help greatly appreciated.
Непрочитано 01.04.2004, 14:44 ADT2004+SP2
VitalyF
hello
This is a right method:
1. uninstall all ADT
2. check 33th physical sector on harddisk, it must be clean
You should not use Again keygen, just use network licence licpath.lic:
3. istall ADT 2004a.
4. register with licpath.lic
5. save adlmdll.dll
6. istall ADT 2004 SP2
7. import "acad_archi.reg" from "\crack" dir into your registry
8. replace adlmdll.dll with saved one.
10. enjoy
Непрочитано 02.04.2004, 11:38
Thank you my friend. I told him your instructions and worked. He didn't check the disk sector though, but he check for all references in the registry and all other leftovers in Application Data and Windows directories.
Непрочитано 02.04.2004, 16:32
Рашит
инженер-строитель
Ottuda
Интересно, вроде не говорит по русски, а попал сюда. Значит может, но не признается. ':?'
Рашит вне форума
Непрочитано 03.04.2004, 15:54
No my friend, I used Google to search for ADT 2004 SP2 crack, then world.altavista.com to translate (badly, but worked somehow) the results. Plus, the phpBB layout is universal and easy to navigate, so I tried to post in the right section of the forum (therefore I used the same section as the previous question I mentioned)
"Interestingly, he does not like speak on Russian, but it fell here. It means can, but it does not acknowledge."
It doesn't need some kind special intelligence to do it
Непрочитано 04.04.2004, 12:43
Рашит
инженер-строитель
Ottuda
Если Ты ищешь crack для ADT 2004 SP2
используй keygen for ADT 2004. Снимает все проблемы в 3 минуты. Поищи на своих гудлах и асталавистах.
Если не найдёшь пиши, пришлю, Друг Ты наш, буржуй.
Удачи.
Рашит вне форума
Непрочитано 05.04.2004, 18:02
Thank you for your offer, but this is solved now
