Функция (n+1) при копировании
Киев
Command: tcount
Select objects: Specify opposite corner: 6 found Select objects: Sort selected objects by [X/Y/Select-order] <Select-order>: s Specify starting number and increment (Start,increment) <1,1>: 1,2 Placement of numbers in text [Overwrite/Prefix/Suffix/Find&replace..] <Prefix>: o 6 objects modified. В результате получим ряд чисел 1, 3, 5, 7, 9, 11 |
