Regen
CNC
Israel
Ну либо (command "_.regen"), либо (command "_.regenall"), либо (vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport) - на выбор
CNC Регистрация: 07.07.2007
Israel
Непомогло, вот, что пишет при первой удачной загрузке
Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: CUSTOM Customization file loaded successfully. Customization Group: VAULT Customization file loaded successfully. Customization Group: EXPRESS Customization file loaded successfully. Customization Group: HEBREW Regenerating model. AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc. Command: Command: AutoCAD menu utilities loaded. Command: COMMANDLINE Command: Command: Command: MY_ARM Command: Point or option keyword required. 2D point or option keyword required. Point or option keyword required. Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". 2D point or option keyword required. 2D point or option keyword required. Point or option keyword required. Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". 2D point or option keyword required. Point or option keyword required. Requires numeric radius, point on circumference, or "D". Unknown command "L". Press F1 for help. Unknown command "DIMENTION". Press F1 for help. Unknown command "C". Press F1 for help. Unknown command "G". Press F1 for help. Command: Specify opposite corner: Command: _.erase 53 found и вот, что пишет при повторной неудачной частичной загрузке. Command: Command: Command: MY_ARM Command: Point or option keyword required. 2D point or option keyword required. Point or option keyword required. Requires numeric radius, point on circumference, or "D". *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Requires numeric radius, point on circumference, or "D". *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object 2D point or option keyword required. 2D point or option keyword required. Point or option keyword required. Requires numeric radius, point on circumference, or "D". *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Requires numeric radius, point on circumference, or "D". *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Requires numeric radius, point on circumference, or "D". *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Requires numeric radius, point on circumference, or "D". *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object 2D point or option keyword required. Point or option keyword required. *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Unknown command "L". Press F1 for help. Unknown command "DIMENTION". Press F1 for help. Invalid window specification. Invalid window specification. Invalid window specification. *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Command: Automatic save to C:\DOCUME~1\vldsa\LOCALS~1\Temp\Drawing1_1_1_4343.sv$ ... Command: |
Отсюды мораль - проблемы в коде. Ставь в нем отлов ошибок, а еще лучше - запускай vlide , в него подгрузить твой лисп (или mnl - не знаю, как ты грузишь), ставить через F9 на первой выполняемой функции точку останова и пошагово проходить по всему лиспу.
Высылай код на мыло. Попробую сегодня глянуть, пока инсталл ADT буду делать
Во-первых, и в-главных, переводи все свои переменные в локальные. Например, как бы я переделал pices:
По отладке - см. аттач. [ATTACH]1186038643.rar[/ATTACH] --- Добавлено: прочитал что написао сначала, чуть кондратий не хватил. Код подправил, так оно (ИМХО) изячнее получится.
И в каком месте ошибка?
А поконкретнее? По-моему, в dcl регистр ключа значения не имеет. Или имеет?
Если второе, поменяй код как требуется. Я-то хотел показать, что (обрати внимание!) после выполнения функции переменные basepath, dclfile_name, dcl_id, res, on_ed1, on_ed2 будут nil!
Israel
Перестройка этой функции неповлияла на основную проблему, как и прежде при вызове функции она исправно открывает все DCL-ки, отрисовывает параметрический чертеж, при повторном запуске и вводе новых параметров все отлично, чертеж накладывается на предыдущий чертеж отрисовывая все полностью, а вот если я пользуюсь командой
erase и запускаю функцию заново, то я получаю неполностью отрисованный чертеж без размерных линии, проблема, но если я опять все вытираю и перд запуском функции набираю комманду (redraw) или (regen) опять все прекрасно работает. Пробовал вставлять в код эти функции результат отрицательный повидимому я некорректно вставляю эти команды..... |
Israel
Ну если имеет, то переименуй left_dcl в Left_DCL и riht_dcl в Riht_DCL соответственно. И все же внеси все переменные в локальные.
Кстати, вопрос - а что делается этим лиспом, если не секрет?
Israel
это автоматизация проектирования для стекольной промышленности, в
данном случае это ряд дверей складывающиеся гармошкой, включая все вырезы для фурнитуры. Проблема остается открытой, как ни странно все функции по отдельности работают адекватно, и еще одно, возможно-ли получить список локальных переменных автоматически, или их надо выкавыривать из кода вручную. |
Армспорт Регистрация: 18.07.2006
Ейск
Твоя прграмма работает некорректнос с первого раза - зто видно из приведённого протокола:
видимо где-то неправильное ключевое слово в Command: Point or option keyword required. 2D point or option keyword required. Point or option keyword required. Requires numeric radius, point on circumference, or "D". Requires numeric radius, point on circumference, or "D". ... Используй отладчик или хотя бы включи CMDECHO и смотри протокол, что бы понять где ошибка. Случайно к примеру заметил в коде Код:
И обязательно используй локальгые переменные - вручную выковыривай! |
Еще одна ошибка:
--- Добавлено: Еще один момент: Код:
Добавлено 2: Во вложении - тот вариант, которым я бы делал (наверное). Хотя почему б не попробовать использовать динамические блоки? Такое может оказаться самым выгодным... [ATTACH]1186081689.rar[/ATTACH]
