Создание Ribbon в Ревите(vb.net API)
Вернуться   Форум DWG.RU > Программное обеспечение > Программирование > .NET > Создание Ribbon в Ревите(vb.net API)
Непрочитано 07.02.2017, 11:19 #1
DEM
YngIngKllr
Создал макрос в Ревите
Вставил полностью код следующего содержания...
[Выделить все]
Imports System.Collections.Generic
Imports System.Linq
Imports System.Text
Imports System.Threading.Tasks
Imports System.Reflection
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.UI
Namespace GrimshawRibbon
	Class App
		Implements IExternalApplication
		' define a method that will create our tab and button
		Private Shared Sub AddRibbonPanel(application As UIControlledApplication)
			' Create a custom ribbon tab
			Dim tabName As String = "Grimshaw"
			application.CreateRibbonTab(tabName)
			' Add a new ribbon panel
			Dim ribbonPanel As RibbonPanel = application.CreateRibbonPanel(tabName, "Tools")
			' Get dll assembly path
			Dim thisAssemblyPath As String = Assembly.GetExecutingAssembly().Location
			' create push button for CurveTotalLength
			Dim b1Data As New PushButtonData("cmdCurveTotalLength", "Total" + System.Environment.NewLine + "  Length  ", thisAssemblyPath, "TotalLength.CurveTotalLength")
			Dim pb1 As PushButton = TryCast(ribbonPanel.AddItem(b1Data), PushButton)
			pb1.ToolTip = "Select Multiple Lines to Obtain Total Length"
			Dim pb1Image As New BitmapImage(New Uri("pack://application:,,,/GrimshawRibbon;component/Resources/totalLength.png"))
			pb1.LargeImage = pb1Image
		End Sub
		Public Function OnShutdown(application As UIControlledApplication) As Result
			' do nothing
			Return Result.Succeeded
		End Function
		Public Function OnStartup(application As UIControlledApplication) As Result
			' call our method that will load up our toolbar
			AddRibbonPanel(application)
		End Function
	End Class
End Namespace
Начинает ругаться на
[Выделить все]
Class "App" должен реализовывать "Function OnStartup(application As UIControlledApplication) As Result" для интерфейса "Autodesk.Revit.UI.IExternalApplication". (BC30149) - E:\System\TMP\{8A2F5EF8-647D-4EAF-895C-109FF1BFC848}\Revit\DocHookups5404\38280000\Res\Source\Res\ThisDocument.vb:13,14
Не фига не пойму, пка, может есть пример создания Ribbon в Ревите...
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
Непрочитано 07.02.2017, 11:39
1 | #2
trir
забыл Implements
[Выделить все]
		Public Function OnStartup(application As UIControlledApplication) As Result Implements IExternalApplication.OnStartup
		End Function
trir вне форума
Автор темы   Непрочитано 07.02.2017, 11:47
DEM
YngIngKllr
Грит
Class "App" должен реализовывать "Function OnShutdown(application As UIControlledApplication) As Result" для интерфейса "Autodesk.Revit.UI.IExternalApplication". (BC30149) - C:\ProgramData\Autodesk\Revit\Macros\2017\Revit\AppHookup\my\Source\my\ThisApplication.vb:13,14
PS. Давно я VB.NET не работал....
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
DEM вне форума
Непрочитано 07.02.2017, 11:49
trir
... и не забудь для OnShutdown тоже самое
trir вне форума
Автор темы   Непрочитано 07.02.2017, 12:18
DEM
YngIngKllr
Угу...
Подредактировал, ошибок при компиляции нету, но панель не появляется
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
DEM вне форума
Непрочитано 07.02.2017, 12:31
trir
а как ты его к Revit'у привязал?
trir вне форума
Непрочитано 07.02.2017, 12:45
YarUnderoaker
Негропроект, инженегр-конструктор
Черкассы
Разве можно для макросов рибон делать? Насколько я знаю, только для аддонов.
YarUnderoaker вне форума
Автор темы   Непрочитано 07.02.2017, 12:50
DEM
YngIngKllr
АААА его надо еще в макросы вставить в
[Выделить все]
Private Sub Module_Startup(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Startup
	TaskDialog.Show("My First Macro", "Module_Startup" )
    End Sub
Или как то по другому???
Я просто с Ревит АПИ, только вчера начал пробовать заниматься..
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
DEM вне форума
Непрочитано 07.02.2017, 13:06
h5r32
Может поможет http://help.autodesk.com/view/RVT/20...4-D189510D3774
Я не программист , сам сижу думаю как бы на этот риборн прикрутить скрипт на питоне , без питон шелл...
Последний раз редактировалось h5r32, 07.02.2017 в 13:13.
h5r32 вне форума
Автор темы   Непрочитано 07.02.2017, 14:38
DEM
YngIngKllr
Сообщение от h5r32 Посмотреть сообщение
Та мне то по фиг могу и на Пайтоне, но блина по пайтону еще меньше сорцев...
Тут самое главное вкурить структуру и последовательность выполнения...
Дальше все пойдет как по маслу...
Буду разбираться тоже, если у тя на пайтоне получится, свистни...
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
DEM вне форума
Непрочитано 08.02.2017, 10:32
miko2009
Инженер-конструктор
Советую сначала ознакомиться с теорией, а потом практиковаться, без файла манифеста тут никак , а Python тут всего лишь инструмент и им нужно правильно пользоваться.
miko2009 вне форума
Непрочитано 09.02.2017, 11:37
extraneous
Не верблюд
Для знакомства с Revit API нужно установить SDK. Там есть большое количество готовых примеров, в том числе и по работе с Ribbon.
Для обучения посмотрите курс "Моя первая программа для Autodesk Revit": http://www.autodesk.ru/adsk/servlet/...36&id=20153867
В качестве справочника по API удобно использовать вот этот ресурс: http://www.revitapidocs.com/
Вот пример создания панели с одной кнопкой в C#. Разрабатывать приложения правильнее в Visual Studio (есть бесплатная версия Community), компилируя код в DLL и подключая в ревит через addin-файл (файл манифеста). В макросах SharpDevelop многое работает не так, как ожидалось.
[Выделить все]
using Autodesk.Revit.UI;
namespace Dimension3D
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class App : IExternalApplication
        public Result OnStartup(UIControlledApplication application)
            string assemblyPath = typeof(App).Assembly.Location;
            string tabName = "Weandrevit";
            application.CreateRibbonTab(tabName);
            RibbonPanel panel = application.CreateRibbonPanel(tabName, "Размеры2");
            PushButton btnDim3d = panel.AddItem(new PushButtonData(
                "Dim3d",
                "3d размер",
                assemblyPath,
                "Dimension3D.CommandDim3d")
                ) as PushButton;
            return Result.Succeeded;
        public Result OnShutdown(UIControlledApplication application)
Мой блог по Revit
extraneous вне форума
Автор темы   Непрочитано 09.02.2017, 12:31
DEM
YngIngKllr
в Ревит SDK пимеры в основном на С#....
Да и то по части 2017 г. тухловато там как то...
А уж по части пайтона http://www.revitapidocs.com/python/
Совсем печально, около 8 примеров всего да то половина толком не работает....
На пайтоне то и VB я нормально прогрммлю(по крайней мере и с OpenCV и с VLC и с Flask и т.д.), просто не могу пока понять структуру программы, да и с методами какая то запарка, у них, половина методов в 2017 не работает, те которое раньше работали.
Нужно бы несколько примеров на пайтоне или vb.net чтобы разобраться...
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
DEM вне форума
Непрочитано 09.02.2017, 14:13
extraneous
Не верблюд
DEM, на vb там тоже есть примеры. Но вообще для Ревита надо бы C# изучить, так как под него больше всего примеров и документации...
Мой блог по Revit
Автор темы   Непрочитано 09.02.2017, 15:18
DEM
YngIngKllr
Сообщение от extraneous Посмотреть сообщение
ПФФФ...
Там такие примеры которые, не работают даже, т.к. сделаны для Revit2013
По сути то разницы нету особой, между С# и VB
Синтаксис чутка отличается...
Вот тут более менее актуальные примеры есть...
https://github.com/ADN-DevTech/RevitTrainingMaterial
----- добавлено через ~6 ч. -----
Собсно если кого заинтересует..
Разработка за деньги
http://forum.dwg.ru/showthread.php?p...60#post1616660
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
Последний раз редактировалось DEM, 09.02.2017 в 15:38.
DEM вне форума
Автор темы   Непрочитано 13.02.2017, 15:15
DEM
YngIngKllr
Нашел на ГитХабе примеры создания Риббонов.
Так что вопрос закрыт...
https://github.com/ADN-DevTech/Revit...evit_API_Intro
Работаю за еду.
Working for food.
Für Essen arbeiten.
العمل من أجل الغذاء
Працую за їжу.
DEM вне форума
C# .net Создание Layout для чертежей, оформленных в модели bargool Готовые программы 656 07.03.2025 21:46
Создание диалоговых окон в AutoCAD TwoZero Программирование 145 11.03.2015 18:15
С чего начать создание модели металлоконструкции? Vitaliy_Bazanin Металлические конструкции 82 06.04.2014 10:50
Помогите с созданием команды. Создание точки с вставкой отметки Z из выбранного текста Tablatura AutoCAD 5 02.08.2013 13:57
Одна из целей: Создание экспертных систем на базе AutoCAD. Сергей Юрьевич Программирование 9 01.01.2005 15:17
