Tool Palettes Window, как сделать удобнее?ACAD 2005.
Опер дир Регистрация: 28.04.2004
А DesignCenter не подходит? Или его в 2005 нет? |
http://www.augi.com/publications/hotnews.asp?page=472 Fly-out Tool (AutoCAD 2004 w/ Extension and up) The Fly-out tool works in a similar fashion to a Fly-out on a Toolbar. It allows you to use a group of tools with common functionality that use the same entity properties like Color and Layer name. There is no way to build a custom Fly-out from the Tool Palette, but they can be created if you venture into the Shape.atc file. The Shape.atc file allows you to create custom Fly-outs with tools. Once you create the Fly-out in the Shape.atc file you have to manually assign it into the Palette file itself. This is not an easy task, but can be very rewarding if you do. I would imagine that there will be a way to create and assign a custom Fly-out in a future release of AutoCAD. То есть пока только ручками only... P.S. Из ДЦ можно накидать на toolpalette блоков по методу drag&drop... |
