Копирование Мтекста с изменением №-ра копии
-------------------------------------------------------------------------------- Adds sequential numbering to text objects. The numbering can appear as a prefix, suffix or replacement text. Command: TCOUNT Select objects: Use an object selection method Sort selection set by X, Y, or Select-order <current>: Enter an option or press ENTER Sorting Options X Places numbers by increasing the x-coordinate value of the selected text. Y Places numbers by decreasing the y-coordinate value of the selected text. Select-order Places numbers according to the order in which the text was selected. Enter count [Start, increment] <current>: Enter the starting number and increment, separated by a comma, or press ENTER Note: Negative increments (decrements) are supported. Precede decrements with a minus sign. Placement of text- Overwrite/Prefix/Suffix/Find&replace../ <current>: Enter an option or press ENTER Placement Options Overwrite Replaces selected text strings with numbers Prefix Adds the number as a prefix to text Suffix Adds the number as a suffix to text Find&replace Replaces a user specified text string with a number Usage Example: text item one text item two text item three text item four text item five Starting number = 1, increment = 1 added as prefix: 1 text item one 2 text item two 3 text item three 4 text item four 5 text item five Starting number = 20, increment = -10 added as suffix: text item one 20 text item two 10 text item three 0 text item four -10 text item five -20 Starting number = 2, increment = 2, Overwrite: 2 4 6 8 10 -------------------------------------------------------------------------------- Express menu: Text Automatic Text Numbering Command line: TCOUNT
Почему все вдруг становятся умными, когда уже не надо? Последний раз редактировалось Disney, 09.12.2009 в 20:10. |
Дизайнер-конструктор Регистрация: 29.05.2004
Kiev
в даунлоаде были мощные нумераторы, и гдето здесь видел поищи: http://lee-mac.com/programs.html
Kiev, Ukraine |
