HEAP Error - что это за зверь?
Вернуться   Форум DWG.RU > Программное обеспечение > AutoCAD > HEAP Error - что это за зверь?
Непрочитано 19.12.2003, 11:46 #1
plaz
Проектирование обустройства нефтяных месторождений
Самара
Есть файл выполненый в Acad200x с кучей xref. Открываю его в R14? но через некоторое время выскакивае alert: Fatal error Heap error. В хелпе нашел про это HEAP:
  • Using AutoCAD Release 14 on Dual Processor Systems
    This version of AutoCAD provides an application that modifies the AutoCAD registry settings so that the MTEXT command is demand loaded rather than autoloaded. Because of a difference in the way dual and single processor computers interact with the multi-threading aspect of the MTEXT command, AutoCAD Release 14 might exhibit one or more of the following problems after initial installation on systems running dual processors:
    AutoCAD tries to run then stops.
    AutoCAD runs and then reports a Heap Error before getting to the Startup Wizard.
    AutoCAD runs but reports an Access Violation Exception, before getting to the Startup Wizard.
    AutoCAD runs, then hangs after you choose the file open tool.
    AutoCAD runs and can open a drawing, however, on when you close, AutoCAD reports an Access Violation Exception.
    NOTE: This problem only affects some systems with dual processors. If your system does not have dual processors, or your dual processor system does not exhibit these problems, you do not need to run the MTEXT AutoLoad Control application.
    This application does not modify AutoCAD system files. It simply modifies the AutoCAD registry settings so that the MTEXT command is demand loaded rather than autoloaded. Demand loading initializes a command at the first use of that command, as opposed to autoloading which initializes the command when AutoCAD starts. After setting MTEXT to be demand loaded, you may notice a slight delay after issuing the first MTEXT-related command in an AutoCAD session. While AutoCAD is not running, perform the following tasks:
    1. From the \Updates\MTALCTRL subdirectory, copy the MTALCTRL.EXE file to any directory on your comuter.
    2. Run MTALCTRL.EXE.
    3. In the MTEXT Auto-Load Control dialog box, choose "Demand-load during the first MTEXT-related command" if your dual processor system exhibits the problems listed above.
    4. Choose OK to save the changes to the registry and exit the dialog box.
    These changes will take effect the next time you run AutoCAD.
В англицком не сильно силен, но прогу нашел и установил. Проблема осталась :cry:
Че делать :?:
[sm1400]
Непрочитано 19.12.2003, 13:59
виталич
Plaz->
Откуда у тебя Dual Processor Systems
виталич вне форума
Непрочитано 19.12.2003, 16:54
Startrek
AutoCAD/AutoLISP
Seattle/USA
Na vsjakii sluchai prover' chtobi vse XREF bili R14. Prover' otkrivajutsja li oni v R14. Neuveren chto pomozhet, no proverit' stoit
Startrek вне форума
Автор темы   Непрочитано 22.12.2003, 07:44
plaz
Самара
2виталич> Сам удивляюсь. :!: А может у меня Cray, а я и не знаю
2Startrek> Все файлы созданы в Acad200x (и Xref тоже), но сохранены как R14. Все эти файлы открываются в R14. Делал даже Recover всех файлов. Может ли данная ошибка быть в следствии того, что у Xref длина названия слоев превышает 31 символ?
plaz вне форума
Непрочитано 22.12.2003, 20:52
AnderGL
инженер
Беларусь
Может стоит тебе задать PROJECTNAME?
В 14 версии при загрузке чертежей,связанных с Xref-чертежами
,программа выполняет поиск Xref по жестко заданному пути.Если
структура каталогов разная,то она не обнаруживает Xref-чертежи.
AnderGL вне форума
