Доступ к объектам скопированным в буфер обмена
Инженер
г. Томск
AutoCAD/AutoLISP Регистрация: 27.08.2003
Seattle/USA
How to Install and Run Clipboard Viewer
View products that this article applies to. Article ID : 141310 Last Review : December 16, 2004 Revision : 1.2 This article was previously published under Q141310 On This Page SUMMARY MORE INFORMATION Windows 95 Windows 98 or Windows Millennium Edition (Me) SUMMARY Clipboard Viewer is not installed by default in Windows. This article describes how to install and run Clipboard Viewer. Back to the top MORE INFORMATION Windows 95 To install Clipboard Viewer, follow these steps: 1. In Control Panel, double-click Add/Remove Programs. 2. Click the Windows Setup tab. 3. Click Accessories, and then click Details. 4. Click the Clipboard Viewer check box to select it, and then click OK. 5. Click OK. To run Clipboard Viewer after you install it, click the Start button, point to Programs, point to Accessories, and then click Clipboard Viewer. You can use Clipboard Viewer to view the contents of the Clipboard. Back to the top Windows 98 or Windows Millennium Edition (Me) 1. Click Start, point to Settings, and then click Control Panel. 2. In Control Panel, double-click Add/Remove Programs. 3. Click the Windows Setup tab. 4. Click System Tools, and then click Details. 5. Click the Clipboard Viewer check box to select it, and then click OK. 6. Click OK To run Clipboard Viewer after you install it, click Start, point to Programs, point to Accessories, point to System Tools, and then click Clipboard Viewer. You can use Clipboard Viewer to view the contents of the Clipboard. Back to the top -------------------------------------------------------------------------------- APPLIES TO • Microsoft Windows 95 • Microsoft Windows 98 Standard Edition • Microsoft Windows Millennium Edition Back to the top Keywords: kbhowto kbsetup KB141310 Back to the top
Сквозь тернии к звездам.... и обратно :yes: |
Инженер Регистрация: 14.05.2006
г. Томск
В общем мне хотелось получить объекты AutoCAD скопированные в буфер обмена в массиве или в коллекции, а затем вставить эти обекты в чертёж в виде блока с обновлением "определений" повторяющихся блоков. Нужна команда обновить блок или вставить объекты из буфера обмена с обновлением блоков. Но потом я понял, что добавить объекты в блок не так то просто, особено это касается размеров. Для объекта AcadBlock не существует методов AddItems как для AcadSelectionSet или метода AddItem. Каждый объект надо добавлять персональным способом, причём о настройке первоначального вида размеров я даже и думать боюсь: как это делать. Было бы замечательно если бы существовал метод:
А в настоящее время мне кажется, что программу обновления определения блоков на VBA написать не возможно. А Вы как считаете? Помогите, если знаете, как это сделать. Если у кого есть специальная программа, которая умеет добавлять в блок часто применяемые объекты чертежа: линии, арки, полилинии, тексты, Мтексты, особено все типы размеров с настройкой первоначального расположения текстов размеров, поделитесь пожалуйста.
С уважением, Михаил! |
Seattle/USA
>>МишаVBA
А для этого как присоветовал Profan прогони через WINDOWS RUN - CLIPBRD.EXE Покопайся в хелпе - там можно сохранять инфу с клипборда в файлы и потом вставлять позже - помоему это то о чем спрашиваеш, короче покопайся в хелпе. :-)
