Ищу EN 12952 Water-tube boilers and auxiliary installations
Вернуться   Форум DWG.RU > Поиск литературы, чертежей, моделей и прочих материалов > Ищу EN 12952 Water-tube boilers and auxiliary installations
Непрочитано 28.09.2011, 08:25 #1
moorch-cat
Техническая диагностика, экспертиза, инспекция, оценка соответствия
Moscow
Ищется EN 12952 Water-tube boilers and auxiliary installations (17 частей):
(зачеркнутые уже найдены)
Part 1: General.
Part 2: Materials for pressure parts of boilers and accessories.
Part 3: Design and calculation for pressure parts.
Part 4: In-service boiler life expectancy calculations.
Part 5: Workmanship and construction of pressure parts of the boiler.
Part 6: Inspection during construction, documentation and marking of pressure parts of the boiler.
Part 7: Requirements for equipment for the boiler.
Part 8: Requirements for firing systems for liquid and gaseous fuels for the boiler.
Part 9: Requirements for firing systems for pulverized solid fuels for the boiler.
Part 10: Requirements for safeguards against excessive pressure.
Part 11: Requirements for limiting devices of the boiler and accessories.
Part 12: Requirements for boiler feedwater and boiler water quality.
Part 13: Requirements for flue gas cleaning systems.
Part 14: Requirements for flue gas DENOX-systems using liquefied pressurized ammonia and ammonia water solution.
Part 15: Acceptance tests.
Part 16: Requirements for grate and fluidized bed firing systems for solid fuels for the boiler.
CR 12952 Part 17: Guideline for the involvement of an inspection body independent of the manufacturer.
УСЁ НАЙДЕНО !
Последний раз редактировалось moorch-cat, 29.09.2011 в 14:37.
