How can I creat a new text file with VBA
Вернуться   Форум DWG.RU > Программное обеспечение > Программирование > How can I creat a new text file with VBA
Непрочитано 13.07.2006, 16:22 #1
To Thuc
I used VBA to calculate, had got some results and now want to write it to a new file. How can I do it ?
Я использовал VBA для вычисления и получил некоторые результаты. Сейчас я хочу записать их в файле. Как я могу этот сделать ?
Непрочитано 13.07.2006, 18:53 Re: How can I creat a new text file with VBA
fixo
Lisp/VBA/VB.NET Hobbyist
Славен Град Петров
Сообщение от To Thuc
I don't know what you exactly need but hope you
will find it useful :
[Выделить все]
Option Explicit
'' written by Joe Sutphin
'' slightly edited for my needs
Public Sub WriteAllPolylinesToFile(strFilename As String)
Dim SelectionSet As AcadSelectionSet
Dim sSet As AcadSelectionSet
Dim intGroupCode(0) As Integer
Dim varDataCode(0) As Variant
Dim LWPolyline As AcadLWPolyline
Dim File As Integer
Dim Column As Long
Dim Row As Long
Dim Lines() As Double
  On Error Resume Next
  'do Lightweight polylines
  intGroupCode(0) = 0
  varDataCode(0) = "LWPolyline"
For Each sSet In ThisDrawing.SelectionSets
Set SelectionSet = sSet
If SelectionSet.Name = "Poly" Then
SelectionSet.Deelete
End If
Next
  'create a selection of all lightweight polylines
  Set SelectionSet = ThisDrawing.SelectionSets.Add("Poly")
  SelectionSet.Select acSelectionSetAll, , , intGroupCode, varDataCode
  If SelectionSet.Count < 1 Then Exit Sub
  File = FreeFile
  'write the polyline vertices to file
  Open strFilename For Append Access Write As #File
    Write #File, "Polyline vertices"
    'go through each polyline object
    ReDim Lines(SelectionSet.Count + 1, 1)
    For Each LWPolyline In SelectionSet
      Write #File, "Polyline Handle: " & LWPolyline.Handle
      For Row = 0 To ((UBound(LWPolyline.Coordinates) + 1) / 2) - 1
        For Column = 0 To 1
          Lines(Row, Column) = LWPolyline.Coordinates(Row + Column)
        Next Column
        Write #File, Lines(Row, 0) & ", " & Lines(Row, 1)
      Next Row
    Next LWPolyline
  Close #File
  If Err Then
    Kill strFilename
    MsgBox "There were errors, no file created!"
  End If
End Sub
Public Sub Start()
  WriteAllPolylinesToFile ("C:\MyVBA\JOE.txt") '' change full path here
End Sub
Fatty
~'J'~
fixo вне форума
Непрочитано 13.07.2006, 19:20
fixo
Славен Град Петров
Here is an easier way I thought
Hope this helps
Give this a try:
[Выделить все]
Public Sub WriteToTextFile(arr As Variant, fName As String)
   Dim fso, tf, i
   Set fso = CreateObject("Scripting.FileSystemObject")
   Set tf = fso.CreateTextFile(fName, True)
   For i = 0 To UBound(arr)
   tf.Write (arr(i))
   tf.WriteBlankLines (1)
   Next
   tf.Close
End Sub
Sub test()
Dim fn As String
Dim myVar(10) As Variant
fn = "C:\MyVBA\FSO2TEXT.txt" '' > change full path by your suit
Dim n
n = 0
Do While n <= 10
myVar(n) = (5 * Rnd) + 1
n = n + 1
Loop
Call WriteToTextFile(myVar, fn)
End Sub
Fatty
~'J'~
fixo вне форума
Автор темы   Непрочитано 15.07.2006, 16:49
To Thuc
I have read the help files anh did the same. But it doesn't work. The error was in this row
I think my Autocad is not right. I'll copy another version and try again.
Thank you.
To Thuc вне форума
Непрочитано 16.07.2006, 01:34
vk
сисадмин
Самара
Error message ...?
vk вне форума
Непрочитано 16.07.2006, 15:06
fixo
Славен Град Петров
Thank you.
Hey, To Thuc, btw, are you from Vietnam or I am wrong?
If so I can to connect you with one vietnamese architect
that is a big guru in VBA
Of course, he'll explain to you all much better than me
You can use this example also:
'' How to write LWPOLYLINE coordinates to text file with
'' delimiters:
[Выделить все]
Option Explicit
Public Sub WriteCoorsToTextFile(ByVal fName As String, ByVal myVar As Variant, ByVal delim As String)
Dim tmpArr() As Variant
Dim i, j As Long
Dim inpStr As String
Dim fDesc As Integer
fDesc = FreeFile
Open fName For Output As fDesc
For i = 0 To UBound(myVar, 1)
inpStr = Str(myVar(i, 0)) & delim & Str(myVar(i, 1))
Print #fDesc, inpStr
Next i
Close #fDesc
End Sub
Public Function Get_Vertices() As Variant
Dim oPoly As AcadEntity
Dim snapPt As Variant
Dim oCoords As Variant
Dim vCnt, vxcnt, iCnt, jCnt As Integer
On Error GoTo Something_Wrong_Here
ThisDrawing.Utility.GetEntity oPoly, snapPt, vbCr & "Select polyline :"
If TypeOf oPoly Is AcadLWPolyline Then
oCoords = oPoly.Coordinates
Else: MsgBox "This object is not" & vbCrLf & "a ""LightWeightPolyline!"""
Exit Function
End If
vCnt = 0
vxcnt = (UBound(oCoords) - 1) / 2
ReDim ptArray(0 To vxcnt, 0 To 1)
For iCnt = 0 To vxcnt
For jCnt = 0 To 1
ptArray(iCnt, jCnt) = oCoords(vCnt)
vCnt = vCnt + 1
Next jCnt
Next iCnt
Something_Wrong_Here:
MsgBox Err.Description
Get_Vertices = ptArray
End Function
Sub TestInput()
Dim fn, d As String
Dim v As Variant
fn = "c:\MyVBA\Coordinates.txt" '' change full path by suit
d = ","
v = Get_Vertices
Call WriteCoorsToTextFile(fn, v, d)
End Sub
Fatty
~'J'~
fixo вне форума
Автор темы   Непрочитано 25.07.2006, 13:20
To Thuc
Сообщение от Fatty
Yes I'm from Viet Nam. How could you know it ?
I'll be verry happy if you can connect me with a vietnamese architect. You see, I've lots of problem with VBA. I'm only a student.
I have sold my problem with another method: OpenAsTextStream. I know that, it isn't best way. This is my code
Private Sub CommandButton3_Click()
Const ForReading = 1, ForWriting = 2, ForAppending = 3
Const TristateUseDefault = -2, TristateTrue = -1, TristateFalse = 0
Dim fs, pro, ts, s
Dim ten, ds As String
Dim sd As Integer
ten = InputBox("Введите имя файла", " Input file's name", "c:\protocol1.txt")
ds = InputBox("Введите количество промежуток", "Input number lines", "20")
sd = CInt(ds)
If (Not IsNumeric(ds)) Or (sd < 0) Then
MsgBox "Количество промежуток не верно!"
Else
Set fs = CreateObject("Scripting.FileSystemObject")
fs.CreateTextFile ten 'Create a file
Set pro = fs.GetFile(ten)
Set ts = pro.OpenAsTextStream(ForWriting, TristateUseDefault)
ts.writeline Now
ts.close
End If
End Sub
To Thuc вне форума
Непрочитано 25.07.2006, 14:01
fixo
Славен Град Петров
Nice work, To Thuc
I had in my young age some friends from Vietnam and
and I know any vietnamese names
You can to connect with my friend from Vietnam, as he said me
on this adress: chubby667@yahoo.com
You can see your work on this forum also:
http://discussion.autodesk.com/forum.jspa?forumID=130
If you will connect with him, let you send my greetings to him
And don't forget about, this forum is good place to get the quick help in lisp and VBA
Here is another one, if this interesting for you:
http://www.autocad.ru/cgi-bin/f1/board.cgi?p=025
Have a good programming
~'J'~
fixo вне форума
