Верхние и нижние индексы в тексте
Вернуться   Форум DWG.RU > Программное обеспечение > AutoCAD > Верхние и нижние индексы в тексте
Непрочитано 02.02.2007, 12:07 #1
Ax3
Programming, automation, CADs, GISs. СибМИР
Россия, Санкт-Петербург
Затрону тему, вероятно, уже всем надоевшую.
Нашел в справке по AutoCAD2004 такую вот вещь:
[Цитата]
To add superscript and subscript definitions to a font
This example procedure is based on the AutoCAD Romans font file, although a similar method applies to any AutoCAD font. This procedure adds four new shape definitions to a font: super_on, super_off, sub_on, and sub_off, which control the position and size of the characters that follow. For simplicity, this example replaces the left- and right-bracket characters ([ and ]) and the left and right curly brace characters ({ and }) with the new characters. You may choose to replace other characters or use a shape number in the extended range (ASCII codes 128 through 256). If you use an extended shape number, you need to use the %%nnn method (where nnn is the ASCII value of the character) for placing the new characters. (See ASCII Codes.)
Edit the SHP (in this case, romans.shp) file with an ASCII text editor. You can create a new file called romanss.shp rather than modify the original file. The romans.shp file is available on the AutoCAD CD.
Search for the shape definitions of the characters you are replacing. To comment out those definitions so the new definitions can take their place, insert a semicolon in front of each line of the shape definition. The shape definition may continue for a number of lines.
The left- and right-bracket characters have ASCII values of 91 and 93 (05B and 05D hex values, if the font is Unicode). The left and right curly brace characters have ASCII values of 123 and 125 (07B and 07D hex).
Add the first and second values on the second line of the definition, and divide the total by 2 as shown in the following example:
*UNIFONT,6,Extended Simplex Roman for UNICODE
21,7,2,0 21 + 7 = 28, then 28 / 2 = 14. This number is used later.
Add the following lines to the end of the SHP file:
*91,8,super_on
2,8,(0,14),003,2,1,0
*93,8,super_off
2,004,2,8,(0,-14),1,0
*123,8,sub_on
2,8,(0,-14),003,2,1,0
*125,8,sub_off
2,004,2,8,(0,14),1,0
Notice the 14 and –14 values in the preceding lines. They are Y axis offsets for the imaginary pen. The value 14 is half the maximum height of a character in this font, which is the correct approximation for superscripts and subscripts. This value needs to be calculated for each font file, but you can modify it any way you want.
Save the file.
Use the COMPILE command to compile the SHP file.
Once the shape is compiled and an appropriate style is defined, you can access the new pen-up and pen-down commands by entering the [, ],
{, and } characters. The [ character initiates superscript and the ] character returns from superscript to normal. The { character initiates subscript and the } character returns from subscript to normal.
[Конец цитаты]
Предлагаю обсудить такой способ создания верхних и нижних индексов.
Непрочитано 02.02.2007, 12:22
translate it, please.
Так как не все разумеют. Вот тогда и получится обсуждение
Непрочитано 02.02.2007, 12:26
Геннадий aka PG
Машиностроение, Проектирование
Абсуждать тоже по англицки будем?
У меня давно в шрифте кроме просто индекса 2, 3 (или показателя степени, разница снизу или сверху) возможен переход "зону" индекса или показателя степени, и пиши там скока влезетю Также есть и возврат.
Подробнее http://www.cadhlp.kulichki.com/pdshx.htm
С уважением,
Геннадий aka PG
Геннадий aka PG вне форума
Непрочитано 02.02.2007, 12:33 Re: Верхние и нижние индексы в тексте
Alan
CAD
Киев
Сообщение от Ax3
>Ax3 А вы вот на этой страничке были?
http://www.kulichki.com/cadhlp/pdshx.htm
А в russ14-pg Геннадий Поспелов добавил верхний/нижний индекс, знак номера. А мы в своё время еще и украинские символы.
См. http://www.kulichki.com/cadhlp/pgtxt.htm
По теории майский жук летать не может.
Но он этого не знает. И летает...
Alan вне форума
Непрочитано 02.02.2007, 12:57
Zouss
в общем смысл этой операции такой:
в шрифт добавляются непечатаемые символы, в которых никакой отрисовки не идет, а меняются расположение базовой линии и масштаб
короче получается нечто похожее на %%u, %%o etc.
Неудобство в том, что в данном случае мы теряем фигурные и квадратные скобки, а если использовать другие символы то вылезет проблема стандартизации. имхо если уж очень много индексов в работе проще использовать ttf
да кстати, данная цитата приводится не в качестве рецепта, а в качестве примера в разделе про создание шрифтов не более того.
Zouss вне форума
Непрочитано 02.02.2007, 13:04
zenon
Остекляем!!! Алюминим!!!
Может это поможет :idea:
[ATTACH]1170410665.rar[/ATTACH]
zenon вне форума
Непрочитано 02.02.2007, 13:05
zenon
И никаких кодов символов не надо запоминать. да и добавлять в файл шрифта ничего не надо.
zenon вне форума
Автор темы   Непрочитано 02.02.2007, 13:08
Ax3
Alan, спасибо за ссылки.
Ax3 вне форума
Автор темы   Непрочитано 02.02.2007, 13:10
Ax3
Геннадий aka PG, вам тоже спасибо.
Ax3 вне форума
Непрочитано 02.02.2007, 13:13
Alan
CAD
Киев
Сообщение от zenon
Может это поможет...
А почему просто не опубликовать, зачем ATTACH?
%%nnn
Вставка символа с номером nnn
Следующие коды можно использовать только со стандартными для AutoCAD текстовыми шрифтами.
%%o
Включение/отключение надчеркивания.
%%u
Включение/отключение подчеркивания.
%%p
Вставляет символа допуска (±).
%%d
Вставляет символа градуса (º)
%%c
Вставка символа диаметра (Ø).
Вставка одного символа процента (%).
Можно одновременно надчеркивать и подчеркивать текст. По достижении конца строки оба режима автоматически отключаются.
Управляющую последовательность кодов %%nnn можно использовать для вставки специальных символов в шрифтах PostScript.
zenon, это должен знать каждый, это есть в любой книжке по Автокаду.
Alan вне форума
Непрочитано 02.02.2007, 13:15
Геннадий aka PG
Сообщение от Ax3
Спасибо очень много! $100 будет вполне достаточно
А что касается запоминания кодов символов - ну а куда деваца было 10 лет назад ??? А необходимость такой записи в чертеже была.
Скажу, более того, коды надо было вводить при нажатом [ALT] на правой (маленькой) клавиатуре, ох как трдно было на ноутбуке...
С уважением,
Геннадий aka PG
Автор темы   Непрочитано 02.02.2007, 13:17
Ax3
zouss, не совсем понял про ttf
Ax3 вне форума
Автор темы   Непрочитано 02.02.2007, 13:23
Ax3
zenon, если не трудно - какой внешний редактор имеется в виду?
А то у меня в mtext строка Autodesk\PAutoCAD так и выводится.
Ax3 вне форума
Непрочитано 02.02.2007, 13:34
Геннадий aka PG
Народ!
Тут могут быть непонятки из-за того , что кто-то использует шрифт где уже есть показатели степени (2,3) и тд и тп, сидящие на кнопках @, #.
(вроде в Arial, Times это есть). Так во это все работает только в этом шрифтовом файле, и это не заслуга какого то там внешнего редактора.
С уважением,
Геннадий aka PG
Непрочитано 02.02.2007, 13:43
Zouss
в общем в shx управлявляющую последовательность для перевода в режим над/подстрочника вы программируете сами так как это показано в примере
в ttf, точнее в mtext эти последовательности уже есть, см. файл выложенный zenon. проблема остается в том как их втыкать - во встроенном редакторе mtext (в 2005 по крайней мере) соответствующих кнопочек нет
в бытность работы в MDT4 я это дело менял вручную - в свойствах для MText, и MDT, и acad показывает все потроха которые там на самом деле содержатся, только в MDT можно залезть в эту строчку и прописать ручками, а в acad работает только кнопочка с троеточием
[ATTACH]1170412933.jpg[/ATTACH]
Zouss вне форума
Непрочитано 02.02.2007, 13:49
Геннадий aka PG
Надо просто узнать код этого символа (например через таблицу символов виндов) в файле ttf, ну и ввести его...
С уважением,
Геннадий aka PG
Непрочитано 02.02.2007, 14:08
А в штатный mtext-редактор можно и вколотить их обработку под конт.меню
Идею не помню где спер, каюсь:
[Выделить все]
*    Добавление стандартных символов в редактор выпадающего текста.
*    Параметры вызова:
*	symbol-list	список точечных пар вида '(("Наименование символа" . "Его описание"))
*    Примеры вызова:
(_kpblc-add-symbols (list
                      (cons "Разработчик" (_kpblc-get-user-name))
                      (cons "Катет" "\U+0009")
                      (cons "Промилле" "\U+2030")
(defun _kpblc-add-symbols (symbol-list / reg_key item counter)
  (setq reg_key
         (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\MTEXT\\Symbols")
        counter 1
        ) ;_ end of setq
  (foreach item symbol-list
    (vl-registry-write reg_key (strcat "Name " (itoa counter)) (car item))
    (vl-registry-write reg_key (strcat "Contents " (itoa counter)) (cdr item))
    (setq counter (1+ counter))
    ) ;_ end of foreach
  ) ;_ end of defun
Автор темы   Непрочитано 02.02.2007, 14:13
Ax3
Все, я догнал. Спасибо за разъяснение, Zouss. То есть в mtext управляющие последовательности в нашем случае надо вводить с помощью <Alt>+<код>. Работает! То есть вариант с *.shx избавляет от необходимости запоминать коды, но ограничен в применении рамками данного конкретного шрифта. Кажется, все прояснилось.
Ax3 вне форума
Автор темы   Непрочитано 02.02.2007, 14:17
Ax3
Здравствуй, kpblc! С интересом читал твои посты в разделе "Программирование". Рад, что ты заглянул и на наш огонек. Пока прелести предложенного тобой варианта не могу оценить, в понедельник, наверно, попробую.
Ax3 вне форума
Автор темы   Непрочитано 02.02.2007, 14:19
Ax3
Господа, всем огромное спасибо.
Сегодня я стал чуть-чуть умнее... :wink:
Ax3 вне форума
