Siemens PLM Femap - 1001 вопрос. - Страница 91
Вернуться   Форум DWG.RU > Программное обеспечение > Расчетные программы > Siemens PLM Femap - 1001 вопрос.
Непрочитано 02.02.2009, 22:02 1 |
Cfytrr
Питер
Siemens PLM Femap
with NX Nastran
"Real FEA made easy"
Тема посвящается вопросам, возникающим при работе в среде программного комплекса Femap
Примеры выполнения некоторых расчетов можно посмотреть:
на домашней страничке
Последний раз редактировалось Cfytrr, 27.09.2013 в 17:54.
Непрочитано 24.01.2013, 20:00
1 | #1801
100k
Жалкий инженеришка-проектаст
немножко спама
вдогонку о контактах, что тут раньше обсуждались
Solid TET to Solid TET Weld connection - best method?
Hello group,
What is the most efficient way to connect multiple parts of a welded assembly together that is meshed with solid tet elements? I have a large FEM with about 20 parts, all welded. The element count is very high, so I don't want to use Connections (Weld) if I don't have to. In the past I have manually connected node to node with RBE2 or beam elements to represent the welds, but this would be very time consuming and tedious on this FEM. I see there are element types called "WELD/FASTENER" type which I have never used. There are many options under "Weld Type", such as patch to patch, Elem to Elem, Elem to Elem vertex, Prop to Prop, Nodes to Nodes, etc. If using these elements is more efficient than the manual RBE2/beam connection method, could someone please recommend which method is best for tet to tet solid connections? Thanks!
The very best solution with FEMAP & NX Nastran to define rigid joints between solids of an assembly is Surface-to-Surface and Edge-to-Surface Gluing, not disccuss at all.
Glue is a simple and effective method to join meshes which are dissimilar. It correctly transfers displacement and loads resulting in an accurate strain and stress condition at the interface. The grid points on glued edges and surfaces do not need to be coincident.
Glue creates stiff springs or a weld like connection to prevent relative motion in all directions.
Surface-to-surface glue definitions are supported in all solution sequences of NX NASTRAN except for SOL 144–146, and 701. In a SOL 153 heat transfer analysis they are treated as conductivity connections. Surface-to-surface glue connections can also be defined between acoustic mesh faces.
100k вне форума
Непрочитано 24.01.2013, 21:54
#1802
Hytrogen
практический смысл в том, чтобы удостовериться, что в данный пакет првильно решает модели как с малым количеством элементов (тестовые, например, на которых проверяется тот или иной нюанс моделирования), так и с большим количеством элементов (несколько тысяч и более)
неужели в Femap такие простые модели (балка и пластинка) вызывают проблемы?? должен же быть способ решить это именно программными средствами)
Hytrogen вне форума
Непрочитано 24.01.2013, 22:18
#1803
100k
так вы и решили, при достижении 80% от нагрузки, относительные деформации достигли предела, после этого происходит разрушение.
100k вне форума
Непрочитано 24.01.2013, 23:22
#1804
Hytrogen
то есть получается, что надо уменьшать величину нагрузки - 80% от 6кН это 4,5 кН
но тогда почему, если я прикладываю 5 кН, то решение расходится на 60% от приложенной нагрузки, т.е. на 3 кН... а когда прикладываю 4 кН - то решение расходится на 70%, т.е. 2.8 кН..
С чем связан такой разброс?? Ведь по логике, если я приложу силу меньшую, чем та, при которой происходит разрушение, то балка должна выдержать...
И получается, что программа при расчете оценивает поведение конструкции не по допустимым напряжениям, а по деформациям?? Значит она сама вычисляет допустимые деформации в зависимости от указываемых мною допустимых напряжений (в свойствах материала) ??
Hytrogen вне форума
Автор темы   Непрочитано 24.01.2013, 23:42
#1805
Cfytrr
Питер
Hytrogen,
Вы что то не так делаете, при нагрузке в 4 кН всё прекрасно сходится.
Тип файла: rar Balka.rar (275.1 Кб, 66 просмотров)
Cfytrr вне форума
Непрочитано 25.01.2013, 14:53
#1806
selega
строительная наука и практика
Минск, Беларусь
Hytrogen,
Почему-то в 11-м не могу открыть файл
selega вне форума
Автор темы   Непрочитано 25.01.2013, 15:06
#1807
Cfytrr
Питер
selega,
сейчас скачал, всё открылось.
В формате 11
Тип файла: rar balka.rar (213.2 Кб, 60 просмотров)
Cfytrr вне форума
Непрочитано 25.01.2013, 15:08
#1808
selega
Минск, Беларусь
Может я что не так делаю... Пробовал и просто neu-файл, открыть, пробовал и экспортировать - ничего не отображается...
Мистика! (C)
selega вне форума
Непрочитано 25.01.2013, 17:06
#1809
100k
Русские имена, разделитель десятичных разрядов (у когото точка, у когото запятая) даж может win32 win64
ставлю на разделитель десятичных разрядов. У Cfytrr запятая у selega точка.
У меня открылся файл.
Последний раз редактировалось 100k, 25.01.2013 в 19:00.
100k вне форума
Непрочитано 25.01.2013, 20:38
#1810
selega
Минск, Беларусь
selega,
В формате 11
В какой версии FEMAP сделан файл?
selega вне форума
Автор темы   Непрочитано 25.01.2013, 21:20
#1811
Cfytrr
Питер
Сообщение от selega Посмотреть сообщение
В 11 версии
Cfytrr вне форума
Непрочитано 25.01.2013, 23:11
#1812
Hytrogen
Сегодня попробовал эту задачу с 4 кН просчитать на работе на 3 разных компах и на разных версиях программы, да еще двоих товарищей подключил, дабы вероятность собственной ошибки исключить. Результат тот же - решение расходится
Плюс, Ваш нейтральный файл, Cfytrr, запустил заново на счет - и та же фигня, не сходится...
А Вы можете скинуть файл модели (модель со всеми Вашими настройками и желательно с результатами) в версии ниже 11, хотя бы 10.3 ??
Hytrogen вне форума
Непрочитано 25.01.2013, 23:22
#1813
selega
Минск, Беларусь
В 11 версии
На домашнем компе все открылось. Буду разбираться, в чем на рабочем причина.
Коллеги, кому-нибудь удалось приобрести новую книгу Рычкова? Мне из интернет-магазина пришел отказ. Мотивировали тем, что книга отсутствует у поставщика. Поставщик, полагаю, из России.
Последний раз редактировалось selega, 25.01.2013 в 23:39.
selega вне форума
Автор темы   Непрочитано 25.01.2013, 23:47
#1814
Cfytrr
Питер
Hytrogen,
Мультик:
Тип файла: flv Балка-4.flv (6.92 Мб, 100 просмотров)
Cfytrr вне форума
Непрочитано 26.01.2013, 00:39
#1815
Hytrogen
Ура, все получилось!!! Премного благодарен!!!
Возможно проблема была связана с тем, что я выбирал метод обновления матрицы жесткости (Stiffness Update) Auto, потому что при методе Iter - все шикарно)) Получается, лучше не давать программе вольностей, а четко указывать каким способом вести решение)))
Hytrogen вне форума
Автор темы   Непрочитано 26.01.2013, 01:00
#1816
Cfytrr
Питер
Hytrogen,
Еще раз хочу заострить Ваше внимание, на том факте, что в этой задаче, в нелинейной постановке, решение при любых настройках должно останавливаться по критерию устойчивости еще задолго до начала текучести, примерно на 18 процентах нагрузки. То факт, что решатель проскакивает этот рубеж и доходит до 100% говорит о издержках "идеальности" модели. Чтоб получить правильный расчет надо ввести или маленькую возмущающую силу, или начальное геометрическое отклонение.
Cfytrr вне форума
Непрочитано 28.01.2013, 15:22
#1817
selega
Минск, Беларусь
В 11 версии
Таки да, был какой-то глюк в файле. Перекачал neu-файл, и все открылось
selega вне форума
Непрочитано 29.01.2013, 12:08
#1818
ьфлы
Артем
Киев
позвольте добавить свой мысли о Stiffness Update:
AUTO – для NL Static – МЖ обновляется ? – при нагрузках значит. меньших критических
ITER - для NL Static – МЖ обновл. после кажд. кол. итераций – при значительных изменений геометрии при деформации (при прощелкивании)
SEMI - для NL Static – МЖ обновляется - немного хуже ITER, но быстрее
TSTEP – для Transient – МЖ обновл. после кажд. кол. итераций - не использовал
ADAPT - не использовал
ИТОГО, чтобы не заморачиваться для NL Static выбирать ITER (но время расчета значительно вырастит в «больших задачах» )
ЗЫ 100k спасибо за спам)
ьфлы вне форума
Непрочитано 30.01.2013, 13:05
#1819
100k
Есть модель + присоединенные массы. Как получить центр масс?
100k вне форума
Автор темы   Непрочитано 30.01.2013, 14:50
#1820
Cfytrr
Питер
Tools-Mass Properties-Mesh Properties- <выбрать сетку и массы> -
Mass__________________________Center_of_Gravity_in_CSys_0
____________________________________X___________Y__________Z
Structural_____________0.0104328____4.38726E-5___-3.95E-14___8.689178
NonStructural__________0.___________0.____________0._________0.
Total_________________0.0104328
___4.38726E-5 ___-3.95E-14 __8.689178
Последний раз редактировалось Cfytrr, 30.01.2013 в 14:59.
Cfytrr вне форума
Plaxis - 1001 вопрос. rust-resisting Расчетные программы 1956 27.08.2015 16:07
