Не вставляются карты в автокаде 2014
Какие карты? Игральные? В чем вопрос-то, попробуй объяснить нормально.
Калининград
А надо было Readme прочитать.
Installation Instructions To install this Hotfix You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process. This installation process requires you to modify an installed product, which may cause Windows security warnings to appear. For all Windows security warnings that appear during installation, click Continue. We recommend that you update your Autodesk applications with the latest service packs or updates. 1. Close all software applications. 2. Navigate to the folder where your Autodesk product is installed. For AutoCAD 2014: C:\Program Files\Autodesk\AutoCAD 2014 3. Right-click AcGeoLocationUI.arx and click Properties. 4. Click the Versions tab and verify the file version. If the version number of AcGeoLocationUI.arx is 19.1.18.0 or 19.1.108.0 then, proceed with installation. If the version number of AcGeoLocationUI.arx is 19.1.108.21 or greater, this hotfix has already been applied and you do not need to proceed with the installation. 5. Right-click AcGeoLocationUI.arx. Rename it as AcGeoLocationUI.bak. 6. Download the Hotfix to a location on your local computer. 7. Extract the downloaded zip file. 8. Copy the extracted file (AcGeoLocationUI.arx) from step 7 (from the x86 or x64 sub-folder depending on whether you have 32-bit or 64-bit software) to your product installation folder i.e. to the folder specified in step 2. 9. Repeat steps 3 and 4 and verify that the file version of AcGeoLocationUI.arx is 19.1.108.21.
На вопрос объяснить поподробней, отвечаю - идите читать Справку, Help, User Manual и т.д. Последний раз редактировалось Кулик Алексей aka kpblc, 28.04.2015 в 20:43. |
Обсуждение фильмов | Perezz!! | Разное | 9712 | 11.08.2025 10:00 |
Civil 2014 - онлайн карты не печатаются. Как печатать... | ziya2014 | Вертикальные решения на базе AutoCAD | 4 | 23.07.2014 12:12 |
Есть ли в автокаде 2014 линейка, чтоб замерить расстояние от линии до линии? | choice_is | AutoCAD | 7 | 11.04.2014 08:53 |
