LISP для создания окна с разрезом стены и утеплителя.
Вернуться   Форум DWG.RU > Программное обеспечение > Программирование > LISP > LISP для создания окна с разрезом стены и утеплителя.
Непрочитано 26.05.2009, 10:20 #1
Scorpio_1986
инженер-проектировщик
Код создания окна
[Выделить все]
; Создание окна
(defun dtr (a)
(* pi (/ a 180.0))
);_ end of defun
(defun sozdrazmer ()
(setq sp (getpoint "\nТочка вставки: "))
(setq ep (getpoint "\nШирина окна: "sp))
(setq tol (getdist "\nШирина стены: "sp))
(setq sh (distance sp ep))
(setq raspl (angle sp ep))
(setq raspl90 (+ raspl (dtr 90)))
(setq raspl180 (+ raspl (dtr 180)))
(setq aspl90 (- raspl (dtr 90)))
);_ end of defun
(defun sozdytipl ()
(command "_lweight" "0.18" "_color" "ByLayer"
"_pline"
(setq p (polar (polar sp raspl180 180) raspl90 120))
(polar p raspl90 130)
) ;_ end of command
(setq yt1 (entlast))
(command
"_pline"
(setq p (polar (polar sp raspl (+ sh 180)) raspl90 120))
) ;_ end of command
(setq yt2 (entlast))
);_ end of defun
(defun razytipl ()
(command "_trim"
yt1
yt2
"_F"
(setq p (polar (polar sp aspl90 1) raspl (/ sh 2)))
(polar p raspl90 (+ tol 2))
) ;_ end of command
);_ end of defun
(defun sozdsten ()
(command "_lweight" "0.4" "_color" "7" "_pline"
sp
(setq p (polar sp raspl90 120))
(setq p (polar p raspl180 60))
(setq tp (polar p raspl90 (- tol 120)))
"_pline"
(setq p (polar sp raspl sh))
(setq p (polar p raspl90 120))
(setq p (polar p raspl 60))
) ;_ end of command
);_ end of defun
(defun sozdrazrez ()
(command "_trim"
(setq p (polar sp raspl90 60))
(polar p raspl sh)
"_F"
) ;_ end of command
);_ end of defun
(defun sozdokno ()
(command "_lweight" "0.2" "_color" "5" "_pline"
sp
(polar sp raspl sh)
"_pline"
(polar p raspl sh)
"_pline"
(setq p (polar tp aspl90 (- tol 220)))
(polar p raspl (+ sh 120))
"_pline"
tp
(polar tp raspl (+ sh 120))
"_lweight" "ByLayer" "_color" "ByLayer"
) ;_ end of command
);_ end of defun
(defun C:OKNO ()
(sozdrazmer)
(setq sosmde (getvar "osmode"))
(setvar "osmode" sosmde)
(setvar "osmode" 0)
(sozdsten)
(sozdrazrez)
(sozdokno)
);_ end of defun
(defun C:OKNO2 ()
(sozdrazmer)
(setvar "osmode" 0)
(sozdytipl)
(razytipl)
(sozdsten)
(sozdrazrez)
(sozdokno)
);_ end of defun
Я LISP изучаю только третий день и это моя первая работа поэтому возможно много ошибок, но она работает. Поэтому приму самую жесткую критику.
Последний раз редактировалось Scorpio_1986, 26.05.2009 в 13:24.
Непрочитано 26.05.2009, 10:27
Ну раз примешь, тогда не обижайся
1. Ни одна переменная не внесена как локальная.
2. Нет обработчика ошибок
3. Насколько я помню, в некоторых случаях при достаточном удалении _.trim может работать некорректно.
Автор темы   Непрочитано 26.05.2009, 10:31
Scorpio_1986
Спасибо за критику! Но как я и говорил я только начинаю изучение LISP. и не знаю как внесте переменную как локальную, как создать обработчика ошибок, про трим я это понимаю но альтернативы еще не нашел Если можно примеры пожалуиста
Scorpio_1986 вне форума
Непрочитано 26.05.2009, 12:02
Alan
CAD
Киев
Сообщение от Scorpio_1986 Посмотреть сообщение
Посмотрите вот эту тему, http://forum.dwg.ru/showthread.php?t=22894 многие Ваши вопросы в ней обсуждались.
По теории майский жук летать не может.
Но он этого не знает. И летает...
Alan вне форума
Автор темы   Непрочитано 26.05.2009, 13:23
Scorpio_1986
Сообщение от Alan Посмотреть сообщение
Alan спасибо за ссылку, обязательно буду читать. Я конечно ожидал комментариев насчет моего кода, ну ладно буду разбираться сам.
А для чего нужна локальная переменная, а для чего аргумент, а когда пустым оставлять?
Последний раз редактировалось Scorpio_1986, 26.05.2009 в 13:40.
Непрочитано 26.05.2009, 22:21
Локальная переменная очищается после выхода из функции. Уничтожается, грубо говоря.
Пример "переделки" (кстати, у тебя в getpoint и getdist ошибки, ты в курсе?):
[Выделить все]
(defun c:okno (/ sosmde)
  (sozdrazmer)
  (setvar "osmode" 0)
  (sozdsten)
  (sozdrazrez)
  (sozdokno)
  ) ;_ end of defun
P.S. Может, тему все же перенести в "Программирование"? Так как предполагается вторая часть по обучению, как я понимаю...
Автор темы   Непрочитано 27.05.2009, 08:24
Scorpio_1986
Насчет getpoint и getdist ошибки заметил буквально вчера если я конечно те ошибки имею ввиду что и вы. Насчет перенесения я не против. Насчет локальной переменной я понял в чем суть, но в моем случаи для обьявления локальных переменных как я думаю надо обьединить на один лисп, насчет osmode при отмены опирации создания окна отключается привязки и что-бы это предотворотить я поставил (setvar "osmode" sosmde) до отключения привязок что-бы при отмене она включался, эти грабли наверное встречались и в других лиспах может есть другое решение
Непрочитано 27.05.2009, 23:13
Вариантов "обхода" туча.
1. Использовать локальный обработчик ошибок наподобие http://www.arcada.com.ua/forum/viewtopic.php?t=445
2. При рисовании командными методами использовать опцию "_none" перед указанием точек.
3. Не использовать командные методы.
Автор темы   Непрочитано 28.05.2009, 08:13
Scorpio_1986
Этот обработчик ошибок я видел но еще не полностью понимаю как она работает.
А отказаться от командных методов мне еще пока думаю рано.
Автор темы   Непрочитано 30.06.2009, 14:13
Scorpio_1986
Я пытался изучить лисп по теме: Научите лиспу на примере (или как kpblc, VVA и компания пытаются обучить чайника лиспу), и пытался довести до ума свой лиспик. Но окончательно запутался что даже не могу понять в чем у меня ошибка. Помогите пожалуиста!!!
[Выделить все]
(defun dtr (a)
  (* pi (/ a 180.0))
     ; Создание окна
(defun C:OKNO (/      sp     ep     pt1    sh   tol  raspl raspl180
        ang    tp     ang180 yt1    yt2   p  st1 st2
        sosmde get_nil     lang   pt0
  (defun *error* (msg)
    (princ msg)    ; Отменено пользователем
    (if sosmde
      (setvar "OSMODE" sosmde)
  ) ;_ end of defun
  (setq get_nil t) ;_Устанавливаем флаг
  (while get_nil
    (setq sp (getpoint "\nТочка вставки (ENTER-Хватит): "))
    (setq pt0 (getvar "lastpoint"))
    (if (equal pt0 sp 0.000001)
      (progn
 (setq get_nil nil) ;_Сбрасываем флаг
      ) ;_ end of progn
      (progn
 (if (not sh)
   (progn
     (setq ep (getpoint "\nТочка определяющая ширину окна: " sp))
     (setq
       pt1 (getpoint "\nТочка определяющая ширину стены: " sp)
     (setq tol (distance sp pt1))
     (setq ang (angle sp pt1))
     (setq lang (- ang raspl))
     (setq tp (polar (polar sp ang tol) raspl 180 60))
     (setq ang180 (+ ang (dtr 180)))
   ) ;_end of progn
   (progn
     (setq ep (getpoint "\nНаправление окна: " sp))
     (setq ang (+ raspl lang))
   ) ;_end of progn
 ) ;_end of if
 (setvar "osmode" 0)
 (command "_lweight"
   "0.18"
   "_color"
   "ByLayer"
   "_pline"
   (setq p (polar (polar sp ang 120) raspl180 180))
   (polar p ang 130)
 ) ;_ end of command
 (command
   "_pline"
   (setq p (polar p raspl (+ sh 360)))
   (polar p ang 130)
 ) ;_ end of command
 (command "_trim"
   yt1
   yt2
   "_F"
   (setq p (polar sp raspl (/ sh 2)))
   (polar p ang tol)
 ) ;_ end of command
 (command "_lweight"
   "0.4"
   "_color"
   "7"
   "_pline"
   sp
   (setq p (polar sp ang 120))
   tp
 ) ;_ end of command
 (setq st1 (entlast))
 (command
   "_pline"
   (setq p (polar p ang 120))
   (polar p ang (- tol 120))
 ) ;_ end of command
 (setq st2 (entlast))
 (command "_trim"
   st1
   st2
   "_F"
   (setq p (polar p ang tol))
 ) ;_ end of command
 (command "_lweight"
   "0.2"
   "_color"
   "5"
   "_pline"
   sp
   (polar sp raspl sh)
   "_pline"
   (polar p raspl sh)
   "_pline"
   (setq p (polar tp ang180 (- tol 220)))
   "_pline"
   tp
   "_lweight"
   "ByLayer"
   "_color"
   "ByLayer"
 ) ;_ end of command
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of defun
Последний раз редактировалось Scorpio_1986, 30.06.2009 в 14:31.
Непрочитано 30.06.2009, 14:51
CB
Конструирование в области нефтеразведки
Гомель
По крайней мере здесь точно
[Выделить все]
(if (not sh)
(progn
(setq
) ;_end of progn
(progn
) ;_end of progn
) ;_end of if
Ты бы поместил сюда картинку, что ты хочешь получить...
CB вне форума
Автор темы   Непрочитано 30.06.2009, 15:43
Scorpio_1986
Я хочу создать лисп для рисования окна с автоматическим разрезом утиплителя и стены, после вставки первого окна операция продолжается только с выбором точки вставки и угла поворота. CB, Makswell там и были ошибки спасибо, теперь работает довольно таки хорошо, но все еще требует доработки.
Спасибо Makswell за внесенные изменения!!! Хотелось бы еще избавиться от команды trim...
[Выделить все]
(defun dtr (a)
  (* pi (/ a 180.0))
                    ; Создание окна
    (if    sosmde
  ) ;_ end of defun
  (while get_nil
    (if sosmde (setvar "osmode" sosmde))
      (progn
      ) ;_ end of progn
      (progn
    (if (not sh)
      (progn
        (setvar "OSMODE" 512)
        (setvar "OSMODE" 128)
        (setq
        (setvar "osmode" 0)
        (setq tp (polar (polar sp ang tol) raspl180 60))
      ) ;_end of progn
      (progn
        (setvar "osmode" 0)
      ) ;_end of progn
    ) ;_end of if
    ;;построение полилинии
    (entmake (list (cons 0 "LWPOLYLINE")
               (cons 100 "AcDbEntity")
               (cons 100 "AcDbPolyline")
               (cons 90 2)    ;количество вершин
               (cons 62 256)    ;номер цвета (0 - поБлоку, 256 - поСлою)
               (cons 370 18)    ;вес полилинии, умноженный на 100 (0.18)
               ;;вершина 1
               (cons 10 (setq p (polar (polar sp ang 120) raspl180 180)))
               ;;вершина 2...
               (cons 10 (polar p ang 130))
               ;; и т.д....
               (cons 90 2)
               (cons 62 256)
               (cons 370 18)
               (cons 10 (setq p (polar p raspl (+ sh 360))))
    (command "_trim"
         yt1
         yt2
         "_F"
         (polar p ang tol)
    ) ;_ end of command
               (cons 90 4)
               (cons 62 7)
               (cons 370 40)
               (cons 10 sp)
               (cons 10 (setq p (polar sp ang 120)))
               (cons 10 (setq p (polar p raspl180 60)))
               (cons 10 tp)
               (cons 90 4)
               (cons 62 7)
               (cons 370 40)
               (cons 10 (setq p (polar sp raspl sh)))
               (cons 10 (setq p (polar p ang 120)))
               (cons 10 (setq p (polar p raspl 60)))
               (cons 10 (polar p ang (- tol 120)))
    (command "_trim"
         st1
         st2
         "_F"
    ) ;_ end of command
               (cons 90 2)
               (cons 62 5)
               (cons 370 20)
               (cons 10 sp)
               (cons 10 (polar sp raspl sh))
               (cons 90 2)
               (cons 62 5)
               (cons 370 20)
               (cons 10 (polar p raspl sh))
               (cons 90 2)
               (cons 62 5)
               (cons 370 20)
               (cons 10 (setq p (polar tp ang180 (- tol 220))))
               (cons 10 (polar p raspl (+ sh 120)))
               (cons 90 2)
               (cons 62 5)
               (cons 370 20)
               (cons 10 tp)
               (cons 10 (polar tp raspl (+ sh 120)))
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of defun
Последний раз редактировалось Scorpio_1986, 01.07.2009 в 14:05.
Нужен Lisp для работы с типами линий Gostushev LISP 12 06.07.2005 14:50
