NETLOAD на целевом компьютере и ошибки System.IO.FileLoadException, System.NotSupportedException
Вернуться   Форум DWG.RU > Программное обеспечение > Программирование > NETLOAD на целевом компьютере и ошибки System.IO.FileLoadException, System.NotSupportedException
Непрочитано 07.09.2012, 11:34 #1
Дмитрий Асташев
päällikön suunnittelijat
Pietari, Venäjä
Коллеги, добрый день!
При попытке загрузки на целевом компьютере приложения, которое стабильно работает на компьютере разработчика, возникает ошибка
[Выделить все]
Command: NETLOAD
Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///D:\acadutil\ACADUTIL.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
File name: 'file:///D:\acadutil\ACADUTIL.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
   at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark)
   at System.Reflection.Assembly.LoadFrom(String assemblyFile)
   at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
   at loadmgd()
Версия NET.Framework совпадает.
VisualStudio на целевом компьютере отсутствует.
Вопрос, возможно ли на целевом компьютере настроить (что-нибудь, где-нибудь), чтобы приложение работало на нем?
PS Вместе с файлом DLL приложения создаются файлы XML и PDB. Добавление
[Выделить все]
<configuration>
   <runtime>
      <loadFromRemoteSources enabled="true"/>
   </runtime>
</configuration>
в XML не помогает.
Непрочитано 07.09.2012, 12:09
hwd
C, C++, C#
С-Пб.
Ты читать умеешь? Тебе в сообщении об ошибках чётко указана причина проблемы. Кроме того, XML бывают разными, вносить изменения нужно в конфигурационный файл приложения, а не создавать его отдельно для своей библиотеки - это не будет работать.
Последний раз редактировалось hwd, 07.09.2012 в 12:14.
hwd вне форума
Непрочитано 07.09.2012, 17:50
1 | #3
Modis
Липецк, Москва
Тыц
Modis вне форума
Непрочитано 07.09.2012, 18:04
hwd
C, C++, C#
С-Пб.
Offtop: меня терзают смутные сомнения(с), что... топикстартер изначально засовывал loadFromRemoteSources в XML файл документации, генерируемой MS VS для Release версии DLL...
hwd вне форума
Автор темы   Непрочитано 07.09.2012, 21:25
Дмитрий Асташев
Pietari, Venäjä
Modis, - спасибо!!! +100500 к репутации!
hwd, - не знаю что и сказать, по прежнему считаю Вас хорошим и неглупым человеком.
Дмитрий Асташев вне форума
Непрочитано 07.09.2012, 21:33
hwd
C, C++, C#
С-Пб.
Сообщение от Дмитрий Асташев Посмотреть сообщение
Я тебе про этот файл (acad.exe.config) вообще-то и писал. Это и есть конфигурационный файл приложения. Именно в нём нужно производить настройки, которые будут распространяться на все управляемые плагины. Например, каталоги поиска управляемых библиотек и их ресурсов (подсказка на будущее).
hwd вне форума
Автор темы   Непрочитано 07.09.2012, 22:32
Дмитрий Асташев
Pietari, Venäjä
Сообщение от hwd Посмотреть сообщение
Андрей, сказал бы просто: "пиши в acad.exe.config" - 5 слов и и все довольны, всем понятно.
Как я мог догадаться куда писать??? В папке с автокадом десяток конфигов и штук двадцать замлов.
Оки? это я так, на будущее.
Воин свирепый машет мечами с утра до заката.
Мастера узнаешь по толчку одною ладонью.
Последний раз редактировалось Дмитрий Асташев, 07.09.2012 в 22:44.
Непрочитано 07.09.2012, 22:46
hwd
C, C++, C#
С-Пб.
В мире .Net, имя конфигурационного файла приложения всегда формируется по правилу [ИмяФайлаСРасширением].config. Поскольку основное приложение - это acad.exe, то наименование конфиг-файла будет acad.exe.config. Я исходил из предположения, что ты в курсе этого правила
Я так понял, что ты пока и в самом .net-программировании не силён, даже без применения его к AutoCAD... Коль дело обстоит так, то рекомендую тебе для начала почитать книжки по самому .net, иначе сложно тебе будет писать .net плагины под AutoCAD. В качестве справочника очень хорош Шилдт, а подробно разжевывает материал Троелсен. Для более углубленных знаний затем очень хорош Рихтер, но только в оригинале, т.к. перевод, как я уже писал - жуток... По поводу отладки .Net приложений, хороша книга Джона Роббинса.
UPD
на тему .NET-программирования в AutoCAD имеются следующие ресурсы:
тынц
тынц
тынц
тынц
Последний раз редактировалось hwd, 07.09.2012 в 22:58.
hwd вне форума
Автор темы   Непрочитано 07.09.2012, 23:39
Дмитрий Асташев
Pietari, Venäjä
Полнота познания всегда означает некоторое понимание глубины нашего неведения.
Р. Милликен
Пребывать в неведении относительно собственной невежественности — такова болезнь невежд.
Олкотт
А ссылки правильные. Список дословно повторяет мою папку ACAD в Избранном
Непрочитано 07.09.2012, 23:43
1 | #10
Флудить-то на фига?
.NET Автоматизация netload во время отладки bargool .NET 13 22.04.2018 23:45
В русской версии AutoCAD 2010 SP1 32-bit файл Acad.PGP содержит ошибки. hwd Баги и пожелания в Autodesk 21 21.04.2010 20:27
Предложение по созданию раздела, в котором нашедшие ошибки в технической, особенно методической, литературе смогут их описать. Amaria Разное 9 24.03.2009 19:38
Ошибки в сортаментах (покушение на основы) IBZ Разное 18 02.09.2008 13:03
