Проблема совместимости с Win7 х64bit
Кстати запустил в безопасной среде выдал следующее
Application does not support just-in-time (JIT) debugging. See the end of this message for details. ************** Exception Text ************** System.UnauthorizedAccessException: Retrieving the COM class factory for component with CLSID {801252FA-5A5C-46C2-B58C-B943A392FA7C} failed due to the following error: 80070005. at Autodesk.InfoCenter.CommunicationCenter.InitCommCenter() at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter() at Autodesk.InfoCenter.PaletteMgr.InitCommCenter() at Autodesk.InfoCenter.PaletteMgr.FirstInvoke() at System.Windows.Forms.Application.RaiseIdle(EventArgs e) at ?A0xa3df2cd1.OnIdle() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- acdbmgd Assembly Version: 17.1.0.0 Win32 Version: 17.1.219.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcdbMgd.DLL ---------------------------------------- msvcm80 Assembly Version: 8.0.50727.4927 Win32 Version: 8.00.50727.4927 CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_88dce9872fb18caf/msvcm80.dll ---------------------------------------- acmgd Assembly Version: 17.1.0.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/acmgd.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- mscorlib.resources Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- AcDashboard Assembly Version: 0.0.0.0 Win32 Version: 17.1.219.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcDashboard.arx ---------------------------------------- AcLayer Assembly Version: 17.1.0.0 Win32 Version: 17.1.219.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcLayer.DLL ---------------------------------------- AcMgdShared Assembly Version: 17.1.0.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcMgdShared.DLL ---------------------------------------- acmgdinternal Assembly Version: 17.1.0.0 Win32 Version: 17.1.219.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/acmgdinternal.DLL ---------------------------------------- AcInfoCenterConn Assembly Version: 17.1.0.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcInfoCenterConn.DLL ---------------------------------------- AdInfoCenter Assembly Version: 17.1.0.0 Win32 Version: 17.1.219.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AdInfoCenter.DLL ---------------------------------------- Autodesk.Interop.AcInetEngine Assembly Version: 17.1.51.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/Autodesk.Interop.AcInetEngine.DLL ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- tlaivzby Assembly Version: 17.1.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Autodesk.Interop.WSCommCntr1 Assembly Version: 17.1.51.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202008/Autodesk.Interop.WSCommCntr1.DLL ---------------------------------------- ************** JIT Debugging ************** Application does not support Windows Forms just-in-time (JIT) debugging. Contact the application author for more information. |
Рязань
Посмотреть как называется файл iso, или папка которую качали. Название можете выложить. Еще при запущенном Автокаде посмотреть Диспетчер Задач -> Процессы, рядом с процессом acad.exe будет что-то вроде (*) или (*32) если автокад 32-битный
autocad2008sp1x64 - это имя файла который скачал и с него ставил. В диспетчере рядом с процессом acad.exe ничего , ни звездочек ни 32... Вот так... причем файлы никакие не окрывает созданные ранее. Что интересно кад то сам открывается... Потом коды предпринимаю попытку открыть файл - в предварительном просмотре он виден , чертеж...
Рязань
Автокад 64-битный значит, тогда другой вопрос - создаются ли новые чертежи (без открытия старых) - т.е. файл -> создать? Можно ли чертить примитивы хотя бы? (линии, прямоугольники и т.п.)?
П.С.: Могу посоветовать скачать х86 версию. Вполне возможно запустится без проблем (самостоятельно или с WinXp mode). |
Читаем правила форума !
Зелик
мои 5 копеек - не удается установить Autocad на XP-mode (win7 x64). Хронически. Ни 2010, ни 2008. Полагаю, этот режим не ладит с видеокартой. Все - лицензия. Кому-нибудь удалось это сделать? Очень бы надо.
Проблема с пространством листа и ограничением печати | Мысь | AutoCAD | 27 | 14.09.2018 13:13 |
Проблема с файлом после импорта из Компас | Alex 166 | AutoCAD | 7 | 22.08.2008 10:33 |
проблема экспорта файлов по IFC из ADT в лиру и ревит | thygank | Revit | 1 | 03.08.2008 18:08 |
Проблема с ксероксом Canon PC860 | _Oleg_ | Разное | 5 | 26.12.2007 10:18 |
Civil 2007 проблема совместимости с AutoCad2006 | Alegzander | Прочее. Программное обеспечение | 5 | 25.05.2007 11:26 |
