Расчет вакуумной системы
Правильно ли будет, если считать так:
This page provides a simplified method for calculating the conductance of a tube and the resulting limitations that the tube places on pumping speed. Calculation of Conductance The following formulas are for dry air at 20º C in the molecular flow region of vacuum. Conductance of a long tube: C = 75D3/L C is Conductance in liters-per-second D is the tube inner diameter in inches L is the tube length in inches So, for example, D is 2.0 inches and L is 20.0 inches. C = (75 x 8)/20 = 30 liters-per-second Conductance Limitations on Pumping Speed The influence of tube conductance on pumping speed is calculated as follows: 1/S act = 1/S spec + 1/C tube Where: Sspec is the specified pumping speed of the pump Ctube is the conductance of the tube attached to the pump Sact is the actual pumping speed at the end of the tube away from the pump So, for example, if Sspec is 50 liters-per-second and Ctube is 30 liters-per-second, 1/Sact = 1/50 +1/30 = 0.020 + 0.033 = 0.053, and, Sact = 1/.0053 = 18.87 liters per second |
Расчет двухскатной крыши зимнего сада из алюминиевой фасадной системы | rfsr | Прочее. Архитектура и строительство | 6 | 29.08.2011 08:48 |
Расчет системы удаления выхлопных газов | Brazda | Инженерные сети | 1 | 15.02.2010 06:57 |
Расчет системы свай с "веерным" расположением | shevtsov_maxim | Основания и фундаменты | 7 | 17.12.2009 11:52 |
Расчет прогона стропильной системы | Иван 80 | Конструкции зданий и сооружений | 81 | 30.03.2008 18:12 |
