VLISP. AutoCAD 7-11. Как определить имя пользователя?
инженер
Украина
специалист по околачиванию грушевых деревьев Регистрация: 14.09.2004
Pietari, Venäjä
Environment Variables Listing.
Compiled and kindly donated by Stig Madsen. Remember that environment variables are dependent on .. well, the environment, so each may or may not apply to a certain setup. Some are almost described, some are definitely not. The first are OS dependent, the rest are AutoCAD dependent. -------------------------------------------------------------------------------- System related (getenv "Path") ;string System search paths (getenv "COMSPEC") ;string Cmd.exe path (getenv "UserName");string User logon name (getenv "Temp") ;string Temp path (getenv "TMP") ;string Temp path (getenv "ComputerName");string Computer name (getenv "Windir") ;string Windows path (getenv "OS") ;string Operating system (getenv "UserProfile");string Current user profile path (getenv "Pathext") ;string Exec extensions (getenv "SystemDrive");string System drive (getenv "SystemRoot");string System root path (getenv "MaxArray");integer -------------------------------------------------------------------------------- General (getenv "ACAD") ;string Support search paths (getenv "ANSIHatch");string Pattern file for ANSI setup 1) (getenv "ANSILinetype");string Linetype file for ANSI setup 1) (getenv "ISOHatch");string Pattern file for ISO setup 1) (getenv "ISOLinetype");string Linetype file for ISO setup 1) (getenv "StartUpType");string Current default for StartUp dialog (getenv "acet-MenuLoad");string Loading of Express Tools menu (getenv "Measureinit");string MEASUREINIT (getenv "InsertUnitsDefSource");integer INSUNITSDEFSOURCE (getenv "InsertUnitsDefTarget");integer INSUNITSDEFTARGET (getenv "acet-Enable");string (getenv "LastTemplate");string Last DWT used (getenv "AcetRText:type");string Current default for RTEXT "Diesel" (getenv "Pickstyle");integer (getenv "Coords") ;integer (getenv "ShowProxyDialog");integer (getenv "Osmode") ;integer (getenv "EdgeMode");integer (getenv "PAPERUPDATE");integer (getenv "ACADPLCMD");string Plotter command string (getenv "ImageHighlight");integer (getenv "Attdia") ;integer (getenv "Attreq") ;integer (getenv "Delobj") ;integer (getenv "Dragmode");integer (getenv "UseMRUConfig");integer (getenv "PLSPOOLALERT");integer (getenv "PLOTLEGACY");integer (getenv "PSTYLEPOLICY");integer (getenv "OLEQUALITY");integer (getenv "Anyport") ;integer (getenv "Validation Policy");integer (getenv "Validation Strategy");integer (getenv "CommandDialogs");integer CMDDIA (getenv "TempDirectory");string Temp dir (getenv "PlotSpoolerDirectory");string Spooler dir (getenv "DefaultLoginName");string Default login (getenv "MenuFile");string Default menu path (getenv "NetLocation");string Default URL (getenv "ACADDRV") ;string Driver path (getenv "ACADHELP");string Help path (getenv "PrinterConfigDir");string Plotter path (getenv "PrinterStyleSheetDir");string Plot styles path (getenv "PrinterDescDir");string Plotter driver path (getenv "NewStyleSheet");string Default .stb/.ctb file (getenv "DefaultFormatForSave");integer Default saveas (getenv "DefaultConfig");string Default pc3 (getenv "LastModifiedConfig");string Last pc3 (getenv "MRUConfig");string pc3? (getenv "ACADLOGFILE");string Logfile (getenv "MaxDwg") ;integer (getenv "AVEMAPS") ;string Texture files path (getenv "TemplatePath");string Templates path (getenv "DatabaseWorkSpacePath");string Data Links path (getenv "DefaultPlotStyle");string e.g. "ByLayer" (getenv "DefaultLayerZeroPlotStyle");string e.g."Normal" (getenv "LineWeightUnits");integer (getenv "LWDEFAULT");integer Default lineweight (getenv "CustomColors");integer (getenv "Blipmode");integer (getenv "ToolTips");string 1) used by MEASUREINIT and MEASUREMENT sysvars -------------------------------------------------------------------------------- Editor Configuration (getenv "SDF_AttributeExtractTemplateFile");string ?? (getenv "AutoSnapPolarAng");string POLARANG (getenv "AutoSnapPolarDistance");string POLARDIST (getenv "AutoSnapPolarAddAng");string POLARADDANG (getenv "AutoSnapControl");integer AUTOSNAP (getenv "AutoSnapTrackPath");integer TRACKPATH (getenv "PickBox") ;integer PICKBOX (getenv "AutoSnapSize");integer (getenv "PickFirst");integer PICKFIRST (getenv "PickAuto");integer PICKAUTO (getenv "MenuOptionFlags");integer MENUCTL (getenv "FontMappingFile");string (getenv "LogFilePath");string (getenv "PSOUT_PrologFileName");string (getenv "MainDictionary");string (getenv "CustomDictionary");string (getenv "MTextEditor");string (getenv "XrefLoadPath");string (getenv "SaveFilePath");string (getenv "AcadLspAsDoc");string -------------------------------------------------------------------------------- Drawing Window (getenv "Background");integer Background color (getenv "Layout background");integer PS Background color (getenv "XhairPickboxEtc");integer Crosshair color (getenv "LayoutXhairPickboxEtc");integer PS Crosshair color (getenv "Autotracking vector");integer Autotracking vector color (getenv "MonoVectors");integer (getenv "FontFace");string Screen Menu (getenv "FontHeight");integer (getenv "FontWeight");integer (getenv "FontItalic");integer (getenv "FontPitchAndFamily");integer (getenv "CursorSize");integer (getenv "HideWarningDialogs");integer:00000008 <- hit (getenv "SDIMode") ;integer:00000000 <- hit -------------------------------------------------------------------------------- Command Line Windows (getenv "CmdLine.ForeColor");integer (getenv "CmdLine.BackColor");integer (getenv "TextWindow.ForeColor");integer (getenv "TextWindow.BackColor");integer (getenv "CmdLine.FontFace");string (getenv "CmdLine.FontHeight");integer (getenv "CmdLine.FontWeight");integer (getenv "CmdLine.FontItalic");integer (getenv "CmdLine.FontPitchAndFamily");integer (getenv "TextWindow.FontFace");string (getenv "TextWindow.FontHeight");integer (getenv "TextWindow.FontWeight");integer (getenv "TextWindow.FontItalic");integer (getenv "TextWindow.FontPitchAndFamily");integer |
Хочу добавить, что все системные переменные можно посмотреть из виндовой командной строки, командой set.
Напомню, для запуска командной строки WIN+R вводим команду cmd и далее жмем ввод. В командной строке, вводим set и любую из переменных можно использовать из автокада, (getenv "здесь переменная") Последний раз редактировалось Елпанов Евгений, 25.08.2010 в 08:57. |
Еще одно дополнение: как правило, регистр имеет значение. (getenv "acad") вернет, скорее всего, nil- в отличие от (getenv "ACAD")
запуск программы из AutoCADа | kminas | Программирование | 19 | 15.06.2012 13:42 |
В русской версии AutoCAD 2010 SP1 32-bit файл Acad.PGP содержит ошибки. | hwd | Баги и пожелания в Autodesk | 21 | 21.04.2010 20:27 |
Перевод имени блока в имя переменной и обратно | Supermax | Программирование | 11 | 14.12.2009 23:26 |
Вариация моделей в SCAD - проблемы с РСУ | UIII | SCAD | 2 | 04.10.2007 13:35 |
Autocad+Visual Basic Переменная среда | Kokep | Программирование | 6 | 08.11.2004 12:29 |
