Печать с помощью драйвера для преобразования формата DWG в PDF (встроенный в AutoCAD)
проектировщик
Житомир
проектировщик Регистрация: 03.05.2007
Житомир
AutoCAD 2008. Без SP.
Проблема решается следующим образом: Установить SP и установить файл с http://usa.autodesk.com/adsk/servlet...linkID=9240618. По установке его целая инструкция: To install the Plot to PDF Not Centered With Custom Margins Hotfix NOTE: You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process. This hotfix should only be applied after installing AutoCAD 2008 SP1 or corresponding service packs for other affected products. 1. Close all software applications. 2. Find the DRV folder under the product installation folder; for example C:\Program Files\AutoCAD 2008\DRV. 3. In this folder, right-click the pdfplot9.hdi file and select Properties. 4. Click the Version tab and confirm the file version. - If the file is version 9.1.219.0 or higher, but less than 9.1.219.27, then proceed with this installation. - If the file is less than version 9.1.219.0, then you must first install AutoCAD 2008 SP1 or corresponding service packs for other affected products. - If the file is version 9.1.219.27 or higher, then this hotfix has already been applied. 5. In the DRV folder under the product installation folder, right-click the pdfplot9.hdi file and rename it pdfplot9.bak. 6. Based on the version of your product, double-click Plot_to_PDF_Hotfix_32bit.zip or Plot_to_PDF_Hotfix_64bit.zip and extract the pdfplot9.hdi file to the product driver installation folder (for example, C:\Program Files\AutoCAD 2008\DRV). 7. Right-click the new pdfplot9.hdi file and select Properties. Click the Version tab and confirm that this file is version 9.1.219.27. NOTE: To remove this hotfix, delete the new pdfplot9.hdi file that you downloaded to the DRV folder and restore the file you renamed in Step 5 to the original name. Но английским плохо владею, не подскажите ли что нужно делать. Последний раз редактировалось Малюк, 05.09.2010 в 07:47. |
Почему все вдруг становятся умными, когда уже не надо? |
Надо просто файл C:\Program Files\AutoCAD 2008\DRV\pdfplot9.hdi заменить на файл, который расположен в архиве по ссылке. И будет всё ок.
Житомир
Поставил AutoCAD 11. Там этой ошибки уже нету. Вопрос такой можно ли как-то задавать настройки DWG в PDF, если да то где и как (под настройками подразумевается: печать в один файл pdf или один лист один файл pdf, вкл/выкл разбивку на слои, вкл/выкл название листов в закладках в pdf файле и так далее)? Да забыл сказать что печатаю из подшивки.
Последний раз редактировалось Малюк, 28.09.2010 в 13:00. |
Печать PDF из AutoCAD 2007 | Shaggy | AutoCAD | 18 | 07.12.2010 13:14 |
dwg по умолчанию не открыть с помощью AutoCAD 2007 | EASports | AutoCAD | 42 | 15.01.2010 05:56 |
Какой программой редактировать файл dwg формата | pavelP2009 | AutoCAD | 1 | 24.07.2009 19:41 |
фаилы формата dwg (формат Autocad) в формат pdf | Zilot | AutoCAD | 4 | 02.12.2003 03:02 |
