изменение параметров размеров с помощью лиспа
Помогаю, кому делать нечего. Регистрация: 27.03.2009
Русская деревня
IAcadDimRotated: Интерфейс AutoCAD для работы с повернутыми размерами.
; Значения свойств: ; AltRoundDistance = 0.0 ; AltSuppressLeadingZeros = 0 ; AltSuppressTrailingZeros = 0 ; AltSuppressZeroFeet = -1 ; AltSuppressZeroInches = -1 ; AltTextPrefix = "" ; AltTextSuffix = "" ; AltTolerancePrecision = 2 ; AltToleranceSuppressLeadingZeros = 0 ; AltToleranceSuppressTrailingZeros = 0 ; AltToleranceSuppressZeroFeet = -1 ; AltToleranceSuppressZeroInches = -1 ; AltUnits = 0 ; AltUnitsFormat = 2 ; AltUnitsPrecision = 2 ; AltUnitsScale = 25.4 ; Application (RO) = #<VLA-OBJECT IAcadApplication 00d73d3c> ; Arrowhead1Block = "STR_RASM" ; Arrowhead1Type = 20 ; Arrowhead2Block = "STR_RASM" ; Arrowhead2Type = 20 ; ArrowheadSize = 5.0 ; DecimalSeparator = "," ; DimensionLineColor = 256 ; DimensionLineExtend = 0.0 ; DimensionLinetype = "Поблоку" ; DimensionLineWeight = -2 ; DimLine1Suppress = 0 ; DimLine2Suppress = 0 ; DimLineInside = 0 ; Document (RO) = #<VLA-OBJECT IAcadDocument 0145b618> ; ExtensionLineColor = 256 ; ExtensionLineExtend = 1.5 ; ExtensionLineOffset = 0.0 ; ExtensionLineWeight = -2 ; ExtLine1Linetype = "Поблоку" ; ExtLine1Suppress = 0 ; ExtLine2Linetype = "Поблоку" ; ExtLine2Suppress = 0 ; ExtLineFixedLen = 1.0 ; ExtLineFixedLenSuppress = 0 ; Fit = 3 ; ForceLineInside = -1 ; FractionFormat = 0 ; Handle (RO) = "4574" ; HasExtensionDictionary (RO) = 0 ; HorizontalTextPosition = 0 ; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 066cfa9c> ; Layer = "RAZM" ; LinearScaleFactor = 1.0 ; Linetype = "BYLAYER" ; LinetypeScale = 1.0 ; Lineweight = -1 ; Material = "ByLayer" ; Measurement (RO) = 160.361 ; Normal = (0.0 0.0 1.0) ; ObjectID (RO) = 2130399520 ; ObjectName (RO) = "AcDbRotatedDimension" ; OwnerID (RO) = 2130390208 ; PlotStyleName = "ByLayer" ; PrimaryUnitsPrecision = 2 ; Rotation = 0.0 ; RoundDistance = 0.0 ; ScaleFactor = 1.0 ; StyleName = "STANDARD$0" ; SuppressLeadingZeros = 0 ; SuppressTrailingZeros = -1 ; SuppressZeroFeet = -1 ; SuppressZeroInches = -1 ; TextColor = 4 ; TextFill = 0 ; TextFillColor = 0 ; TextGap = 1.5 ; TextHeight = 3.5 ; TextInside = 0 ; TextInsideAlign = 0 ; TextMovement = 0 ; TextOutsideAlign = 0 ; TextOverride = "" ; TextPosition = (224.165 186.167 0.0) ; TextPrefix = "" ; TextRotation = 0.0 ; TextStyle = "STANDARD" ; TextSuffix = "" ; ToleranceDisplay = 0 ; ToleranceHeightScale = 1.0 ; ToleranceJustification = 1 ; ToleranceLowerLimit = 0.0 ; TolerancePrecision = 2 ; ToleranceSuppressLeadingZeros = 0 ; ToleranceSuppressTrailingZeros = 0 ; ToleranceSuppressZeroFeet = -1 ; ToleranceSuppressZeroInches = -1 ; ToleranceUpperLimit = 0.0 ; TrueColor = #<VLA-OBJECT IAcadAcCmColor 066eb278> ; UnitsFormat = 2 ; VerticalTextPosition = 1 ; Visible = -1 Все эти свойства объекта "Размер" легко можно программно изменить. Кусочек кода - меняет цвет текста на желтый (цифра 2): Код:
ЗДЕСЬ лежат бесплатные Lisp-ы Последний раз редактировалось E-degtyarev, 26.07.2011 в 10:28. |
Посмотри здесь (Вертикальная выноска линейного размера). Может что-нибудь подойдет
Просто огромное СПАСИБО! за помощь!!!
вот как я применил: Код:
часто получается после простановки размеров нужно сделать так чтобы размеры остались а dim line почти исчезли, приходилось их помечать и в свойствах менять ext line fixed и ext line fixed length. теперь стало намного проще. Ещё раз спасибо! Последний раз редактировалось Кулик Алексей aka kpblc, 27.07.2011 в 08:37. Причина: ошибка |
Русская деревня
Молодец, делаешь успехи. Можно доработать еще немного: выбрать сразу несколько размеров, поместив их имена в список, а затем, пройдясь по списку всем сразу придать нужные свойства.
ЗДЕСЬ лежат бесплатные Lisp-ы |
МИХАИЛCAD, а кричать-то зачем?
Коллеги, подскажите, пожалуйста, в чём затык?
Пытаюсь программно поменять размеру стрелку: Цитата:
Другому размеру вручную назначен данный блок на стрелку, то есть, в чертеж он загружен. |
Так ты посмотри, какое реальное имя у этого блока (разбей размер и через (cdr (assoc 2 (entget (car (entsel))))) узнай имя).
Как поменять visibility set c помощью лиспа | Zaghim | LISP | 12 | 10.05.2011 16:33 |
Печать нестандартных размеров листа с помощью плоттера, подключенного через маршрутизатор | _Nikita_ | Прочее. Программное обеспечение | 3 | 02.09.2010 10:25 |
Как включить перемещение и изменение размеров инструментальных палитр? | nicestep | AutoCAD | 1 | 12.07.2010 10:19 |
Изменение параметров дин блока | ch-viktor | Программирование | 5 | 23.05.2008 21:38 |
Изменение свойств текстов и размеров | Кулик Алексей aka kpblc | Программирование | 2 | 23.06.2005 16:11 |
